QNAP TVS-863-8G/80TB (8x10TB Seagate NAS HDD) 8 Bay NAS
Quicklinx: CB91WS00 Mfr#: TVS-863-8G/80TB-S
  • Windows 8 (32/64 bits)
Adorned with a box in gold color, the sophisticated TVS-863, featuring the easy-to-use QTS operating system, is a powerful, reliable, secure and scalable NAS solution designed for mission-critical and intensive business applications and to meet fast growing data storage needs. The TVS-863 supports 10GbE via optional PCI-E network expansion and delivers high performance with persistent throughput, providing a comprehensive storage solution for SMBs to build a reliable private cloud.
  • High performance & efficiency
    The TVS-863+ is equipped with the energy-efficient 64-bit AMD quad-core processor with DDR3 RAM, SATA 6 Gb/s, and 2 Gigabit LAN ports for lightning-fast multi-tasking. The TVS-863+ is a powerful NAS that delivers up to 448 MB/s read & write speeds with 4 x GbE port configuration, and up to 1,432 MB/s with 10GbE configuration. The TVS-863+'s hardware-accelerated encryption engine provides unmatched encryption performance in its class, up to 691 MB/s with AES-256 bit full NAS volume encryption, boosting system performance & security while ensuring the safety of sensitive business data stored in the TVS-863+. The next-gen AMD Radeon HD graphics provides hardware-accelerated transcoding performance and dual HDMI outputs with brilliant high-definition multimedia content playback. When installed with the latest Wi-Fi 802.11ac USB network adapter, the TVS-863+ can offer remarkably high speeds for transferring large amount of files and streaming bandwidth-consuming multimedia.
  • QTS - simple and efficient
    Thanks to the intuitive user interface of QTS, system operations of the TVS-863+ are smooth and handy. Its intelligent desktop allows you to find desired functions quickly, create desktop shortcuts or group shortcuts, monitor important system information on a real-time basis, and open multiple application windows to run multiple tasks concurrently, bringing greater operating efficiency.
  • 10GbE ready
    The TVS-863+ offers 2 inbuilt Gigabit Ethernet ports & 1 pre-installed 10GbE PCI-E NIC (single port), supporting 10 Gigabit high speed network. The 10GbE-ready TVS-863+ delivers lightning-fast data throughput. Coupled with its large storage capacity potential, the TVS-863+ is perfect for data centers to store big data and excel in fast data transmission, and for 10GbE home lab environment for technical professionals.
  • Use your TVS-863+ as a PC with the exclusive QvPC technology
    QNAP's exclusive QvPC technology consolidates a number of high-end technologies including VM integration, multimedia transcoding, HDMI output, cloud integration and NAS connection technologies, allowing users to operate the TVS-863+ as a PC when they plug in a keyboard, mouse and monitor. With QvPC technology, the TVS-863+ is transformed into a cost-effective device with PC functionalities for users to operate the system via "HybridDesk Station" on the screen to directly access stored data, run multiple applications using Windows/Linux/UNIX/Android-based VMs, surf the web on Google Chrome or Mozilla Firefox, watch Full HD videos with up to 7.1 channel audio with XBMC, and much more.
  • More screen to see: QvPC 4K Ultra HD display via HDMI
    Capture more details with 4K resolution! Coupled with QvPC Technology, you can connect the TVS-863+ to a 4K UHD monitor via HDMI to take advantage of 4K's impeccable image detail for increased productivity. Photographers can view sharper and clearer high-resolution images, and you can get a larger workspace with one monitor when managing virtual machines.
  • Run additional operating systems on the TVS-863+
    With the support for AMD-V virtualization technology, the TVS-863+ can operate the virtualization station, transforming the TVS-863+ into a 2-in-a-box NAS that can function as an all-in-one NAS and a virtualization platform that supports multiple operating systems, fast virtual machine (VM) creation, VM import/export, snapshot, and enables desktop operations on web browsers. With the easy-to-use interface, you can centrally manage all of the VMs created on the TVS-863+ with minimal effort. You can also download VMs on demand from online VM markets and import them to the TVS-863+ without any complex procedures.
  • Enjoy the best audiovisual experience with HD station and dual HDMI
    QNAP's HD station integrates the powerful XBMC media player and web browser. The splendid user interface and support for crystal-clear 7.1-surround sound passthrough brings smooth playback of Full HD videos, providing you with the perfect home theater experience. The TVS-863+ features dual HDMI outputs, allowing you to connect to two monitors to play the same content with concurrent 1080p HDMI displays. You can even watch YouTube videos, surf the web and manage the Turbo NAS using Google Chrome or Mozilla Firefox with multilingual keyboard input. The HD Station supports multi-tasking and user authentication so only authorized users can access data stored on the TVS-863+ via HDMI monitors.
QNAP TVS-863 Turbo NAS - NAS server - 80 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
80 TB
8 (installed) / 8 (max)
29.82 cm x 23.54 cm x 18.52 cm
1 x AMD 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 5 hot spare, 6 hot spare, 10 hot spare
Hard Drive
8 x 10 TB SATA 6Gb/s - NAS compatible
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
8 GB
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
80 TB
29.82 cm
23.54 cm
18.52 cm
Enclosure Colour
Gold
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
1 x AMD 2.4 GHz
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB (installed) / 16 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
HDD - hot-swap - 3.5"
8 x 10 TB
Interface Type
SATA 6Gb/s
NAS compatible
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, automated backup scheduling, Real-time Remote Replication (RTRR), signage station
Encryption Algorithm
SSL, TLS, FIPS 140-2, 256-bit AES
UPnP
Security DVR
40
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 2.0 x4 , 2 (total) / 1 (free) x SO-DIMM 204-pin
2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 3.0 - Type A , 2 x HDMI output , 1 x management
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, lockable, built-in 2 cooling fans, scheduled power on/off
Security Slot Type
Kensington security slot
FIPS 140-2
2 x front panel key
Internal power supply
Power Provided
250 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
Sound Emission
21.3 dBA
