QNAP TVS-673-16G 6 Bay NAS Desktop
Quicklinx: D88SWS00 Mfr#: TVS-673-16G
The TVS-673 is powered by an AMD embedded Accelerated Processing Unit (APU) that incorporates exceptional CPU and AMD Radeon R7 Graphics performance, delivering a high-performance and energy-efficient NAS solution. Built with a state-of-the-art metal design and topped off with a stylish gold finish, the TVS-673 features a powerful quad-core CPU, AES-NI hardware encryption engine, 64 GB RAM, USB 3.1 (10 Gbps) and 10GbE expandability with exceptional performance. Coupled with the unique USB QuickAccess, HDMI 4K output, and 4K H.264 video decoding and encoding acceleration, the TVS-673 running on the 64-bit QTS 4.3 operating system provides an optimum audiovisual experience and well-rounded private cloud system.
  • Top-class hardware engineering
    The sturdy and feature-packed hardware of the TVS-673 bolsters overall system performance. Coupled with the flexible and expandable architecture, the TVS-673 can fulfill diversified application needs.
  • Flexible 10GbE network expandability
    The TVS-673 features two PCIe (Gen. 3 x4) slots, one preinstalled with a USB 3.1 Type-A dual-port card, and the other allows for installing an optional dual-port 10GbE (10GBASE-T or SFP+) network card. This allows for greater flexibility in setting up 10 GbE environments for high-performance virtualization and backup tasks.
  • USB 3.1 (10 Gbps) connectivity
    USB 3.1 provides faster maximum speeds of 10 Gb/s - double that of USB 3.0 - to greatly boost data transfer performance. The TVS-673 comes with a USB 3.1 Type-A dual-port card for connecting up to two USB devices, allowing compatibility with newer, faster USB devices for transferring large-sized media files.
  • M.2 SSD & 2.5" SSD cache with Qtier optimization
    The TVS-673 supports 2.5" SSD for caching to increase IOPS performance, and provides higher transfer speeds and reliability with additional two M.2 SATA 6 Gb/s SSDs. Using an SSD cache boosts overall system performance, and is perfect for improving the overall workflow of random IOPS demanding applications such as virtualization. The TVS-673 combines M.2 SSD, SATA SSD and high-capacity HDD in one box to effectively realize tiered storage for exceptional application performance and lower TCO of storage at the same time.
QNAP TVS-673 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 6 (max)
26.43 cm x 27.96 cm x 18.82 cm
5.63 kg ()
1 x AMD R-series Embedded RX-421BD 2.1 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
72
RAM
16 GB
Storage Operating System
QNAP QTS 4.3
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
26.43 cm
27.96 cm
18.82 cm
5.63 kg ()
Enclosure Colour
Gold
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
16 GB (installed) / 64 GB (supported) - DDR4
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS, SFTP
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, IPP, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
NAT support, hardware encryption, trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, Spanning Tree Protocol (STP) support, backup server, download client, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, reset button, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, SNMP support, Apple AirPlay, Dropbox support, automated backup scheduling, Wi-Fi USB dongle support, Real-time Remote Replication (RTRR), Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support
Encryption Algorithm
SSL, TLS, FIPS 140-2, 256-bit AES
UPnP
Security DVR
72
Expansion Bays
6 (total) / 6 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x PCI Express 3.0 x4 , 4 (total) / 2 (free) x SO-DIMM 260-pin , 2 (total) / 2 (free) x M.2
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.1 - Type A , 2 x HDMI output , 2 x microphone - mini-jack , 1 x audio out - mini-jack , 4 x USB 3.0 - Type A
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, wake on LAN, built-in 2 cooling fans, scheduled power on/off
FIPS 140-2
Remote control
Internal power supply
Power Provided
240 Watt
QNAP QTS 4.3
5 - 95% (non-condensing)
