Your basket is empty
QNAP TVS-671-i3-4G 18TB-Red 6 Bay  Desktop NAS
Quicklinx: B55FWS00 Mfr#: TVS-671-I3-4G/18TB-RED
  • Core i3
The TVS-671 is a powerful NAS storage solution designed for I/O-intensive tasks, mission-critical business applications and fast-growing data storage needs. Incorporating reliability and security, the TVS-671 delivers high performance with persistent throughput and provides a comprehensive storage solution for SMBs to build a reliable private cloud.
QNAP TVS-671 - NAS server - 18 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
18 TB
6 (installed) / 6 (max)
25.7 cm x 23.5 cm x 17.5 cm
1 x Intel Core i3 4150 3.5 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
6 x 3 TB
10Mb LAN, 100Mb LAN, GigE
RAM
4 GB
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows XP or later, Microsoft Windows Server 2003 or later
NAS server
Host Connectivity
Gigabit Ethernet
18 TB
25.7 cm
23.5 cm
17.5 cm
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
4 GB (installed) / 16 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap
6 x 3 TB
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, NTP server, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, Apple AirPlay, anti-virus protection
Encryption Algorithm
SSL, TLS, FIPS 140-2, 256-bit AES
UPnP
Expansion Bays
6 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x PCI Express 2.0 x4 , 2 (total) / 0 (free) x SO-DIMM 204-pin
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x HDMI output
4 x network cable
Security lock slot (cable lock sold separately), audible alarm, lockable, built-in 2 cooling fans
FIPS 140-2
2 x front panel key
Internal power supply
Power Provided
250 Watt
QNAP QTS 4.1
Software Included
QNAP Virtualization Station
5 - 95% (non-condensing)
Sound Emission
21 dB
