The QNAP TVS-471U, featuring the easy-to-use QTS operating system, provides a reliable and scalable NAS solution to fulfill data backup, file synchronization and remote access. The TVS-471U is 10GbE-ready, delivers exceptional performance, and supports cross-platform file sharing, comprehensive backup solutions, iSCSI and virtualization applications, and many practical business functions, making it the ideal choice for SMBs to secure important business data.
Internal cache port for IO acceleration
The TVS-471U supports two on-board internal cache ports. By installing mSATA flash modules, the IOPS performance of storage volumes can be remarkably boosted. It is perfect for improving the overall workflow of random IOPS demanding applications such as databases and virtualization. The internal cache port design does not require the space of a hard drive tray to allow for more storage capacity. -
10GbE ready
The TVS-471U offers four inbuilt Gigabit Ethernet ports and supports 10 Gigabit high speed networks by installing a 10GbE network adapter. The 10GbE-ready TVS-471U delivers lightning-fast data throughput and coupled with the support for a large storage capacity is perfect for data centers to store big data, excel in fast data transmission, and for editing large size videos on-the-fly without transferring the videos between the TVS-471U and desktop computers. -
Use your TVS-471U with exclusive QvPC technology
QNAP's exclusive QvPC Technology consolidates a number of high-end technologies including VM integration, multimedia transcoding, HDMI output, cloud integration and NAS connection technologies, allowing users to operate the TVS-471U when they plug in a keyboard, mouse and monitor.
- QNAP TVS-471U - NAS server - 24 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 1U
- Total Storage Capacity
- 24 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 43.9 cm x 49.9 cm x 4.4 cm
- 7.63 kg ()
- Processor
- 1 x Intel Core i3 4150 3.5 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 4 x 6 TB SATA 6Gb/s - Enterprise
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.1
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows XP or later, Microsoft Windows Server 2003
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 24 TB
- 43.9 cm
- 49.9 cm
- 4.4 cm
- 7.63 kg ()
- Built-in Devices
- Status LCD, led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 4 GB (installed) / 32 GB (supported) - DDR3
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 4 x 6 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
- Buffer Size
- 128 MB
- Enterprise
- Data Link Protocol
- TCP/IP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
- Encryption Algorithm
- 256-bit AES
- UPnP
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express 3.0 x4 , 1 (total) / 1 (free) x PCI Express 3.0 x8
- 4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 2.0 - Type A , 4 x USB 3.0 - Type A , 1 x HDMI output
- Cables Included
- 4 x network cable
- Audible alarm, lockable, built-in 2 cooling fans
- FIPS 140-2
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- QNAP QTS 4.1
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
