The TVS-471 is a powerful NAS storage solution designed for I/O-intensive tasks, mission-critical business applications and fast-growing data storage needs. Incorporating reliability and security, the TVS-471 delivers high performance with persistent throughput and provides a comprehensive storage solution for SMBs to build a reliable private cloud.
- QNAP TVS-471 - NAS server - 16 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 16 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 18 cm x 23.5 cm x 17.7 cm
- Processor
- 1 x Intel Core i3 4150 3.5 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
- Hard Drive
- 4 x 4 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.1
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows XP or later, Microsoft Windows Server 2003
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 16 TB
- 18 cm
- 23.5 cm
- 17.7 cm
- Built-in Devices
- Status LCD, led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 4 GB (installed) / 16 GB (supported) - DDR3
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
- HDD
- Capacity
- 4 x 4 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
- Encryption Algorithm
- 256-bit AES
- UPnP
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express 2.0 x4 , 1 (total) / 1 (free) x PCI Express 3.0 x8
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x HDMI output
- Cables Included
- 4 x network cable
- Audible alarm, lockable, K-lock security slot, built-in 2 cooling fans
- FIPS 140-2
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- QNAP QTS 4.1
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Sound Emission
- 17.3 dB
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.00 | in stock |
£1,469.76
saving £2.50
saving £2.50
