The TS-963X is an affordable NAS for small and medium-sized businesses (SMBs) with AMD Embedded G-Series GX-420MC quad-core 2.0 GHz processor, 9 drive bays and a built-in 5-speed 10GBASE-T port for up to 10Gb connectivity. Four 2.5-inch drive bays can be used to install SSDs to enable caching and Qtier technology. One built-in 5-speed 10GBASE-T port (10G/5G/2.5G/1G/100M) also increases productivity of businesses with existing Cat 5e/6 cables, without extra costs or additional installation procedures. Combined with several QNAP technologies including VJBOD, Container Station, and Virtualization Station, the TS-963X has the potential to empower a wide range of business applications and can also be easily expanded to fit future data storage requirements.
Built-in 10GBASE-T port for accelerated workflows
The TS-963X supports the out-of-box 10 GbE connectivity with a built-in 10GBASE-T port that supports five speeds. The 10GBASE-T port utilizes the Aquantia AQtion AQC107, an enterprise-class multi-gigabit Ethernet controller, which lets you quickly perform more applications such as database transfers, virtual machine storages and big data backups. -
Boost performance with SSDs and Qtier
The TS-963X comes with four dedicated 2.5-inch drives bays that are ideal for installing SSDs. With SSDs, you can enable Qtier which offers both tiered storage and cache-like mechanisms for both volumes and iSCSI LUNs. This allows the TS-963X to be further accelerated to meet the performance requirements of demanding applications such as virtualization. -
High-flexibility virtualization and virtual switches
The TS-963X supports versatile virtualization technologies such as containers (LXC and Docker) and virtual machines (VMs), so you can easily migrate existing applications to or deploy new solutions on the TS-963X. Virtual switches support several modes for connecting containers, VMs, NAS, and physical network interfaces for flexibly deploying business IT infrastructure while ensuring high security. -
Convenient file exchange with cross-platform file sharing and Qsync
The TS-963X supports SMB/CIFS, NFS, and AFP protocols for file sharing across Windows, Mac, Linux/UNIX networks. Data can be centrally stored and protected by rigid security measures provided by the TS-963X. The Windows AD and LDAP services enable system administrators to configure user permissions by using an existing Windows AD server, LDAP server or built-in LDAP service. To sync data across devices, including mobile phones and tablets, simply install Qsync Central on the NAS and Qsync clients on other devices to enjoy a fast, private, secure and real-time file sync service. -
Reliable, high-performance storage for virtualization
The TS-963X supports block-based iSCSI LUN that provides a more reliable and isolated environment than file-based LUN. Supporting VMware, Citrix, Microsoft Hyper-V and Windows Server 2016, the TS-963X provides a high-performance, reliable and affordable storage solution for virtualization environments. VMware VAAI and Microsoft ODX are also supported to increase performance by offloading server loading for ESXi server and Hyper-V respectively, and supporting QNAP vSphere Client plug-in and QNAP SMI-S provider with enhanced operational efficiency and management in virtualization applications.
- QNAP TS-963X - NAS server - 0 GB
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- Installed Devices / Modules Qty
- 0 (installed) / 9 (max)
- 32.93 cm x 27.96 cm x 18.82 cm
- 3.53 kg
- Processor
- 1 x AMD G-Series GX-420MC 2 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 50, JBOD, 60
- Networking
- 100Mb LAN, GigE, 10 GigE, 5 GigE, 2.5 GigE
- IP Cameras Supported
- 3000
- RAM
- 2 GB
- Power
- AC 120/230 V
- Storage Operating System
- QNAP QTS 4.3.4
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.7 Lion, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
- NAS server
- Host Connectivity
- 0 GB
- 32.93 cm
- 27.96 cm
- 18.82 cm
- 3.53 kg
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 16 GB (supported) - DDR3L
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60
- Data Link Protocol
- TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, SMB, DDNS
- Remote Management Protocol
- SNMP 2, SNMP, Telnet, SNMP 3, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DHCP, DDNS, Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- NAT support, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, IPv6 support, firmware upgradable, proxy server, Spanning Tree Protocol (STP) support, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, Network Access Protection (NAP), bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, Dropbox support, Real-time Remote Replication (RTRR), Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, DLNA support, file station, hubiC support, OpenStack Swift-compatible, WebDAV server support, port trunking, Microsoft Azure support, Amazon S3 support, Amazon Glacier suport, HiDrive support, RTRR server, RTRR client
- Encryption Algorithm
- AES-NI
- UPnP
Security DVR
- 3000
- Expansion Bays
- 5 (total) / 5 (free) x hot-swap - 2.5" / 3.5" , 4 (total) / 4 (free) x hot-swap - 2.5"
- Expansion Slots
- 2 (total) / 1 (free) x SO-DIMM 260-pin
- 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x Ethernet 10Gb - RJ-45 , 2 x USB 2.0 - Type A , 1 x audio out - mini-jack
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan, built-in speaker
- Security Slot Type
- Kensington security slot
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 53.06 Watt
- Power Consumption Stand by
- 35.64 Watt
- Power Provided
- 120 Watt
- QNAP QTS 4.3.4
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Sound Emission
- 17.3 dBA
