QNAP TS-932X-2G 9 Bay Desktop NAS - Diskless
Quicklinx: DMMPWS00 Mfr#: TS-932X-2G
Capacity: 0GB
Interface: 10 Gigabit Ethernet, Ethernet, Fast Ethernet, Gigabit Ethernet
Type: 9-bay
Hurry, only 1 left in stock!
£506.46 ex VAT
£607.75 inc VAT
The business-class TS-932X is a budget-friendly NAS designed to accommodate five 3.5-inch hard drives and four 2.5-inch SSDs. It is also the first ARM-based NAS that supports Qtier technology for efficient auto-tiered storage. As a 9-bay NAS, the compact TS-932X takes up less desktop space compared with other models in the same class, and presents a stylish control panel embellished with brushed-metal aluminum. Featuring dual 10GbE SFP+ ports, the TS-932X provides an excellent blend of speed and affordability to future-proof your IT infrastructure for 10GbE networks.
  • Slim size, big capacity, quality & stylish
    You may be surprised with the size of the TS-932X, which is a 9-bay NAS with a similar appearance as a regular 4-bay/6-bay NAS. The TS-932X strikes a balance between storage capacity and performance, making it a perfect companion for small and medium organizations and small offices. Remarkable design details also include succinct LED indicators, a brushed-metal aluminum control panel, and a unique drive bay layout that efficiently streamlines the physical footprint of the NAS.
  • Quad-core CPU and dual 10GbE SFP+ ports
    The TS-932X is equipped with an AnnapurnaLabs, an Amazon company Alpine AL-324 quad-core 1.7 GHz Cortex-A57 processor with big DDR4 RAM and supports SATA 6 Gb/s. When processing AES 256-bit full NAS volume encryption, the TS-932X also provides unmatched encryption performance while ensuring the safety of sensitive business data stored in the NAS. The TS-932X comes with a pair of 10GbE SFP+ ports to fully support 10GbE high-speed networks, delivering a major speed increase for virtualization tasks, fast backup & restoration, and large-data applications.
  • Optimized collaboration with seamless file sharing and sync
    The TS-932X centrally stores data and files, and supports SMB/CIFS, AFP and NFS protocols for file sharing across Windows, Mac, and Linux /UNIX networks. Coupled with Qsync (a utility that turns a QNAP NAS into a safe, high-capacity data center for file synchronization) any file uploaded to the TS-932X will be made available for all linked devices, such as computers, laptops and mobile devices. You can sync shared folders and team folders for group file sharing to enhance the flexibility of team projects and collaboration. Files can be centrally managed using File Station, including files from mobile devices and optical disc drives. File Station also allows you to mount a remote NAS, and transfer files between your NAS and public cloud services for greater convenience.
  • Flexible and economical storage expansion
    You need an easy solution to increase storage capacity when running out of space. QNAP provides several ways to expand your NAS storage as needed to accommodate data and business growth.
QNAP TS-932X - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Total Storage Capacity
0 GB
0 (installed) / 9 (max)
18.27 cm x 22.36 cm x 22.47 cm
3.53 kg
1 x Annapurna Labs Alpine AL-324 1.7 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 50, JBOD, 5 hot spare, 6 hot spare, 60, 50 hot spare, 10 hot spare, 60 hot spare
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
2 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.3.4
NAS server
Host Connectivity
0 GB
18.27 cm
22.36 cm
22.47 cm
3.53 kg
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
(supported) 2 GB (installed) / 16 GB (supported) - DDR4
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 60, RAID 50 hot spare, RAID 10 hot spare, RAID 60 hot spare
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS, SMSC
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
VPN support, LDAP support, wake on LAN (WOL), Syslog support, print server, IPv6 support, backup server, Trivial File Transfer Protocol (TFTP) support, iTunes server, DHCP server, bandwidth control, IPv4 support, surveillance station, DLNA Media Server, Apple Time Machine compatible, DHCP client, Apple AirPlay, Dropbox support, Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Chromecast support, OpenStack Swift-compatible, Microsoft Azure support, Amazon S3 support, Amazon Glacier suport, RTRR server, RTRR client
Encryption Algorithm
SSL, FIPS 140-2, 256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
5 (total) / 5 (free) x hot-swap - 2.5" / 3.5" , 4 (total) / 4 (free) x hot-swap - 2.5"
Expansion Slots
1 (total) / 0 (free) x SO-DIMM 260-pin
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x Ethernet 10Gb - SFP+ , 1 x audio out - mini-jack
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, built-in speaker, hardware encryption
Security Slot Type
Kensington security slot
External power adapter
AC 120/230 V
Power Provided
120 Watt
QNAP QTS 4.3.4
Shipping Weight
5.06 kg
5 - 95% (non-condensing)
Sound Emission
18.7 dBA
Capacity: 0GB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Type: 9-bay
Brand: QNAP
Price Range Ex VAT: 500 - 750
