QNAP TS-877XU-1200-4G 8 Bay Rack Mountable
Quicklinx: DTKSWS00 Mfr#: TS-877XU-1200-4G
Powered by AMD's powerful Ryzen processor, the TS-877XU is capable of boosting virtual machine performance with up to 4 cores/4 threads and Turbo Core up to 3.4 GHz. Four PCIe Gen.3 slots provides expandability to provide more potential applications and functionality for the TS-877XU.
  • Top-class hardware engineering with high I/O expandability
    The hardware design of the TS-877XU provides exceptional system performance and expandability to fulfill diverse application requirements.
  • Absolute performance with AMD Ryzen and up to 64GB RAM
    Powered by a high-performance AMD Ryzen 3 1200 processor with AES-NI encryption acceleration and up to 64GB DDR4 RAM, the TS-877XU delivers aggressive yet power-smart performance to meet your multitasking demands. For resource-demanding business applications such as VDI, R&D, private cloud, and server virtualization, look no further than the TS-877XU.
  • Dual-channel Memory to deliver power-smart performance
    The TS-877XU supports dual-channel DDR-4 memory and four Long-DIMM slots. When using paired memory modules, the TS-877XU can leverage the power of dual-channel architecture to boost performance. You also customize the memory configuration (supports up to 64GB RAM) of the TS-877XU, making it the most ideal and cost-efficient storage solution for environments like virtualization that contain dynamically-changing workloads.
  • Extend NAS functionality with PCIe slots
    The TS-877XU features four PCIe slots that allow for installing 10GbE/40GbE network cards, QM2 M.2 SSD/10GbE PCIe cards, or compatible wireless network cards for greater application potential.
  • Install a graphics card for GPU-accelerated computing
    Graphics cards are optimized for graphical calculations and transformations, but require significantly more power than other hardware. The TS-877XU offers a 350 watt power supply and PCIe slots to support low-profile graphics cards that do not need power cables, including AMD Radeon or NVIDIA GeForce graphics cards to boost performance of applications such as video editing, 4K UHD transcoding, imaging processing in QTS and performance of virtual machines via GPU pass-through.
  • GPU-accelerated NAS for AI machine learning
    The TS-877XU provides cutting-edge capabilities to help organizations develop cost-efficient AI-oriented Big Data storage solutions. Combined with a high-end graphics card and QNAP's "QuAI" AI developer package, the AMD Ryzen-based TS-877XU can be leveraged to quickly build, train, and optimize AI model-based services, beneficial for exploring intelligent services and greater business value.
  • SSD caching and auto tiering enable 24/7 optimized storage efficiency
    The TS-877XU provides four PCIe slots that allow for installing QNAP's innovative QM2 cards to add M.2 SSD applications, such as SSD caching, to the NAS. Using an SSD cache boosts overall system performance, and is perfect for improving the overall workflow of random IOPS demanding applications such as virtualization. Qtier Technology empowers the TS-877XU with auto tiering that further helps continuously optimize storage efficiency across M.2 SSD, SSD, high-capacity SATA drives, and the optional PCIe NVMe SSD with around-the-clock acceleration. The new Qtier 2.0 features IO-awareness that empowers SSD tiered storage with a cache-like reserved space to handle burst I/O in real time, greatly maximizing the advantages of SSD.
  • Optimized performance for VMware Virtualization with iSER
    With the built-in dual 10GbE ports that natively features Mellanox ConnectX-4, the TS-877XU supports the iSCSI Extensions for RDMA (iSER) protocol to boost data transfer performance of the TS-877XU as VMware ESXi storage and to reduce the CPU load of the ESXi server. iSER can provide a significant increase in performance, providing an essential tool to optimize demanding virtualization applications.
  • Block-based iSCSI LUN: ideal choice for virtualization storage
    The TS-877XU supports block-based iSCSI LUN that provides a more reliable and isolated environment than file-based LUN. Supporting VMware, Citrix, Microsoft Hyper-V and Windows Server 2016, the TS-877XU provides a high-performance, reliable and affordable storage solution for virtualization environments, while also supporting VMware VAAI and Microsoft ODX to increase performance by offloading server loading for ESXi server and Hyper-V respectively, and supporting QNAP vSphere Client plug-in and QNAP SMI-S provider with enhanced operational efficiency and management in virtualization applications.
QNAP TS-877XU - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10Gbps SFP+
Enclosure Type
Rack-mountable - 2U
0 (installed) / 8 (max)
48.2 cm x 56.2 cm x 8.83 cm
10.99 kg ()
1 x AMD Ryzen 3 1200 3.1 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, JBOD, 60
1GbE, 10 GigE optical
RAM
4 GB
Storage Operating System
QNAP QTS 4.3.4
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
48.2 cm
56.2 cm
8.83 cm
10.99 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
3.4 GHz
RAM
4 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, file sharing, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, bandwidth control, IPv4 support, surveillance station, online RAID capacity expansion, online RAID level migration, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, VPN client, Chromecast support, file station, IFTTT agent, FXP support, hybrid backup sync, Qfiling, Qsirch, Qcontactz, Qfinder Pro, Q'center (NAS CMS)
Encryption Algorithm
AES, FIPS 140-2, 256-bit AES
UPnP
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
4 (total) / 3 (free) x DIMM 288-pin , 2 (total) / 2 (free) x PCI Express 3.0 x8 , 2 (total) / 2 (free) x PCI Express 3.0 x4
2 x Ethernet 1000Base-T - RJ-45 , 1 x USB 3.1 - Type A , 4 x USB 3.0 - Type A , 1 x USB 3.1 Gen 2 - Type C , 2 x Ethernet 10Gb - SFP+
2 x network cable
Built-in 2 cooling fans
24 x flat head screws (for 2.5" HDD), 32 x flat head screws (for 3.5" HDD)
Internal power supply
73.1 Watt
Power Provided
350 Watt
QNAP QTS 4.3.4
5 - 95% (non-condensing)
Sound Emission
35.2 dBA
