QNAP TS-873-4G/64TB-RED 8 Bay NAS
Quicklinx: DLLBWS00 Mfr#: TS-873-4G/64TB-RED
The TS-873 is powered by a high-performance and energy-efficient CPU and provides two PCIe slots for greater functionality. You can install a QNAP QM2 expansion card to add M.2 SSD caching/10GbE connectivity; a compatible wireless card to use the TS-873 as a wireless access point; and an entry-level graphics card to boost system performance for 4K video performance. The TS-873 allows you to flexibly deploy a wide range of applications with a more affordable budget.
QNAP TS-873-4G - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 8 (max)
32.93 cm x 27.96 cm x 18.82 cm
6.59 kg ()
1 x AMD R-series Embedded RX-421ND 2.1 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
10Mb LAN, 100Mb LAN, 1GbE
RAM
4 GB
Storage Operating System
QNAP QTS 4.3.4
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
32.93 cm
27.96 cm
18.82 cm
6.59 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
3.4 GHz
RAM
4 GB (installed) / 64 GB (supported) - DDR4
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, SMTP, FTP, DHCP, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, DDNS, Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
NAT support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, Spanning Tree Protocol (STP) support, download client, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, Virtual Switch Bonding (VSB), Apple AirPlay, event notification, push notification, Chromecast support, file station
Encryption Algorithm
SSL, TLS, FIPS 140-2, 256-bit AES, AES-NI
UPnP
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
4 (total) / 2 (free) x DIMM 288-pin , 2 (total) / 2 (free) x M.2 , 2 (total) / 2 (free) x PCI Express 3.0 x4
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans
Security Slot Type
Kensington security slot
Internal power supply
Installed Qty
1
Max Supported Qty
1
Power Provided
250 Watt
QNAP QTS 4.3.4
5 - 95% (non-condensing)
Sound Emission
23.4 dBA
