Product
QNAP TS-863U-RP-4G/32TB-RED PRO 8 Bay Rackmount NAS
Quicklinx: BYCVWS00 Mfr#: TS-863U-RP-4G/32TB-RED PRO
The TS-863U-RP is a powerful network storage system powered by a high-performance processor. It provides 10GbE to optimize ROI, and doubles the encrypted file transfer performance with the AES-NI hardware-accelerated encryption engine. The TS-863U-RP provides versatile all-in-one server functionalities as well as advanced features including Virtualization Station, which allows users to run VMs on the same device. The TS-863U-RP is designed for small and medium-sized businesses looking for backup, restoration, private cloud, storage for virtualization and to future-proof their IT infrastructure for 10GbE networks.
  • 10GbE connectivity
    The TS-863U-RP supports 10 Gigabit high-speed networks with an included single-port SFP+ 10GbE network adapter in addition to the default 2 Gigabit Ethernet ports. It delivers fast data throughput for businesses that demand higher bandwidth for virtualization and fast backup and restoration for an ever-growing amount of data.
  • Bridge between 1 and 10GbE to optimize network accessibility
    With Qswitch the TS-863U-RP supports bridging 1 Gigabit and 10 Gigabit networks naturally like a network switch. You can connect 1GbE devices to the TS-863U-RP to attain the 10GbE working environment for data transmission.
  • Seamless capacity expansion
    The TS-863U-RP supports online capacity expansion by cascading multiple QNAP RAID expansion enclosures to meet the needs of growing business data.
  • High reliability design ensuring business continuity
    The business-ready TS-863U-RP is designed to provide long operations and services. The support for comprehensive RAID configurations and hot-swapping allow for replacing hard drives without service interruption.
  • Simple and efficient
    Thanks to QTS’s intuitive user interface, system operations of the TS-863U-RP are smooth and handy. Its intelligent desktop allows you to find the desired functions quickly, create desktop shortcuts or group shortcuts, monitor important system information on a real-time basis and open multiple application windows to run multiple tasks concurrently, bringing greater working efficiency.
  • Qsirch - a smarter, faster way to search
    Quickly and easily find documents, photos, videos, and music with Qsirch, that lets you find what you need by real-time, natural search. Simply type in as much as you know about what you are trying to find, including bits of the file name or even words or phrases in the document and Qsirch will display a list of matches, complete with thumbnails, as you type.
  • Run additional operating systems on the TS-863U-RP
    The TS-863U-RP is empowered by AMD virtualization technology to support virtualization station, transforming it into a 2-in-a-box device that can function as an all-in-one NAS and a virtualization platform.
  • Powerful QNAP flexible volume
    QNAP's flexible volume provides a more secure and flexible way to store NAS data. This volume offers powerful features such as storage pooling with multiple RAID group protection, thin provisioned volumes with space reclaim, block-level iSCSI LUN, and online capacity expansion.
  • Volume and LUN snapshot simplifies restoration
    QTS Storage Manager adds an easy-to-use web-based snapshot tool for you to easily back up and restore data on the TS-863U-RP back to any point of time to prevent the loss of important data.
  • Disaster recovery solutions brings peace of mind
    The TS-863U-RP offers various data recovery possibilities. RTRR supports real time or scheduled data backup to a remote Turbo NAS or FTP server and synchronizes files to a remote folder from a local folder with better backup efficiency and reduced backup time.
  • Comprehensive security possibilities
    In open network environments, business data may be exposed in a potential hack. The TS-863U-RP provides numerous security possibilities, such as encrypted access, IP blocking, and more.
  • File synchronization across multiple devices
    The Qsync utility turns your TS-863U-RP into a high-capacity, safe data center for file synchronization. Any file uploaded to the TS-863U-RP will be made available for all linked devices, such as computers, laptops or mobile devices.
QNAP TS-863U-RP - NAS server - 32 TB
NAS server
Host Connectivity
Gigabit Ethernet / 10Gbps SFP+
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
32 TB
8 (installed) / 8 (max)
48.2 cm x 53.4 cm x 8.9 cm
11.02 kg
1 x AMD G-Series 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 5 hot spare, 6 hot spare, 10 hot spare
Hard Drive
8 x 4 TB
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
4 GB
Power Redundancy
Storage Operating System
QNAP QTS 4.2
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
32 TB
48.2 cm
53.4 cm
8.9 cm
11.02 kg
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 16 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
HDD - hot-swap
8 x 4 TB
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, print server, IPv6 support, backup server, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, iTunes server, Jumbo Frames support, DHCP server, FTP server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, SFTP client
Encryption Algorithm
SSL, 256-bit AES
UPnP
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCI Express 2.0
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 1 x Ethernet 10Gb - SFP+
2 x network cable
Built-in 2 cooling fans
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
250 Watt
QNAP QTS 4.2
5 - 95%
