The TS-853BU-RP is a 2U rackmount NAS that easily fits into a standard 19-inch rack, providing an ideal storage solution in the server room for small and medium businesses. The TS-853BU-RP comes with a PCIe slot for boosting potential applications: the QNAP QM2 expansion card can be installed to add an M.2 SSD cache/10GbE connectivity, a compatible wireless card can be installed to use the TS-853BU-RP as a wireless access point, and a USB 3.1 card can be added for easier backup to/from multiple external storage. The TS-853BU-RP also provides a wide range of value-added features: 4K video playback and real-time transcoding; deployment of virtual environments through Virtualization Station and Container Station.
Extend NAS functionality with PCIe expansion
The TS-853BU-RP has a PCIe expansion slot, providing flexibility in extending NAS functionality and potential applications. Install a QNAP QM2 card to provide M.2 SSD caching/10GbE connectivity, or use the TS-853BU-RP as a wireless access point by installing a compatible wireless network card, or boost the USB connectivity of the TS-853BU-RP by installing a USB 3.1 card. -
SSD cache acceleration
The TS-853BU-RP supports SSD caching. Users can install an SSD in drive bay 1 and bay 2 to boost IOPS performance of storage volumes. Coupled with Qtier auto-tiering technology, users can customize storage allocation to suit their system environment and application demands. -
Data backup, recovery, and synchronization
Hybrid Backup Sync provides a well-rounded solution for data backup, file synchronization and disaster recovery for you to easily and securely backup data from your NAS to several local, remote and cloud storage spaces. In the event of system crashes or critical hardware failure, you can quickly restore data from these storage spaces, minimizing downtime and reducing overall loss. -
Secure access with VPN & Proxy Server
The QVPN combines VPN server and VPN client functionality. Through QVPN, the TS-853BU-RP can be used as a VPN server with L2TP/IPsec, OpenVPN, and PPTP support, allowing you to securely access data shared within the private local network. The TS-853BU-RP can also be used as a VPN Client to connect to other VPN servers or virtual private network through PPTP and OpenVPN for secure data transmission. VPN Client also allows your NAS to connect to multiple servers at the same time. -
Qfiling automates your file organization
Qfiling helps automate file organization for sorting files spread through multiple folders, helping to reduce the time needed for finding important files. Users can categorize files and determine filing conditions; and schedule filing tasks to be carried out periodically. The "Recipe" feature allows users to save frequently-used filing conditions as an "exclusive recipe", then the next Qfiling task can be run with just one click using the recipe. -
4K HDMI output for an excellent audiovisual experience
The TS-853BU-RP supports dual-channel 4K H.264/H.265 hardware decoding and real-time transcoding, allowing you to convert videos to universal file formats that can be smoothly played on multiple devices.
- QNAP TS-853BU-RP - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Installed Devices / Modules Qty
- 0 (installed) / 8 (max)
- 48.2 cm x 53.4 cm x 8.9 cm
- 11.02 kg ()
- Processor
- 1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 5 hot spare, 6 hot spare, 10 hot spare
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 8 GB
- Storage Operating System
- QNAP QTS 4.3
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 48.2 cm
- 53.4 cm
- 8.9 cm
- 11.02 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 8 GB DDR3L
- Flash Memory Installed
- 4 GB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
- Data Link Protocol
- TCP/IP, PPTP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, print server, IPv6 support, backup server, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, iTunes server, Jumbo Frames support, DHCP server, FTP server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, SFTP client
- Encryption Algorithm
- SSL, 256-bit AES
- UPnP
- Expansion Bays
- 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 x PCI Express 2.0 x2
- 4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 2.0 - Type A , 1 x HDMI output
- Cables Included
- 2 x network cable
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 1
- 63.3 Watt
- Power Provided
- 250 Watt
- QNAP QTS 4.3
- 0 °C
- 40 °C
- 5 - 95%
