- QNAP TS-831XU-RP - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Enclosure Type
- 2U
- Installed Devices / Modules Qty
- 0 (installed) / 8 (max)
- 48.2 cm x 53.4 cm x 8.9 cm
- 12.55 kg ()
- Processor
- 1 x Annapurna Labs Alpine AL-314 1.7 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
- IP Cameras Supported
- 72
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.3
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows 7, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2
- NAS server
- Host Connectivity
- Enclosure Type
- 2U
- Total Storage Capacity
- 0 GB
- 48.2 cm
- 53.4 cm
- 8.9 cm
- 12.55 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 4 GB (installed) / 16 GB (supported) - DDR3
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
- Data Link Protocol
- TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
- Hardware encryption, VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, reset button, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR), Google Drive support
- Encryption Algorithm
- SSL, TLS, 256-bit AES
- DLNA CERTIFIED, UPnP
Security DVR
- 72
- Expansion Bays
- 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCI Express 2.0 x2
- 2 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x Ethernet 10Gb - SFP+ , 1 x management
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), audible alarm, built-in 2 cooling fans, scheduled power on/off
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- 64.36 Watt
- Power Provided
- 250 Watt
- QNAP QTS 4.3
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Sound Emission
- 48.3 dBA
