The TS-653 is a powerful, reliable, secure and scalable NAS solution, designed for mission-critical business applications and to meet fast growing data storage needs. The TS-653 supports SATA drives and delivers high performance with persistent throughput, providing a comprehensive storage solution for SMBs to build a reliable private cloud.
High performance
Powered by an excellent processor with energy-efficient memory, coupled with the support of SATA, 4 Gigabit LAN ports and HDMI output, the TS-653 is a powerful NAS, that delivers fast read and write speeds. The TS-653 can also automatically increase the processor's clock rate when needed for CPU-intensive tasks. The TS-653's fast encryption and decryption performance provides high transfer speeds with AES 256-bit volume encryption, boosting system performance and security, while ensuring the safety of sensitive business data, stored in the TS-653. When installed with the dual-band Wi-Fi network card, the TS-653 can offer remarkably high speeds for transferring large amount of files and streaming bandwidth-consuming multimedia. -
Comprehensive security solutions
In open-network environments, business data may be exposed in a potential hack. The TS-653 provides numerous security solutions, such as encrypted access, IP blocking, and more. IT administrators can also control the access rights of each user to different folders, preventing unauthorized access to important files. The TS-653 is validated with military-level AES 256-bit encryption, preventing sensitive business data from unauthorized access and breach, even if the hard drives or the entire system were stolen. -
Real-time and offline HD video transcoding
The TS-653 delivers superior real-time Full HD video transcoding to convert videos to formats, that can be smoothly played on PCs, mobile devices and Smart TVs. It allows for a few devices to simultaneously view different videos, stored on the TS-653 with on-the-fly hardware-accelerated transcoding. The TS-653 allows you to enjoy instant videos on multiple devices - even those, that lack computing power or have limited file format support - without the need for complicated and time-consuming file conversion. With the benefit of offline transcoding, if you can only connect to an Internet connection with limited/restricted bandwidth, you can still enjoy smooth videos by selecting a pre-rendered lower resolution to play the videos without affecting the TS-653's system performance, running other applications. This also allows more people to play videos via streaming. The TS-653 also allows you to set a dedicated folder for automatic video transcoding.
- QNAP TS-653B - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 6 (max)
- 23.5 cm x 22.6 cm x 16.8 cm
- 3.01 kg ()
- Processor
- 1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 40
- RAM
- 8 GB
- Power
- AC 120/230 V
- Storage Operating System
- QNAP QTS 4.3
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 23.5 cm
- 22.6 cm
- 16.8 cm
- 3.01 kg ()
- Built-in Devices
- 0.96-inch OLED
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.3 GHz
- RAM
- 8 GB (installed) / 8 GB (supported) - DDR3L
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
- Data Link Protocol
- TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, proxy server, web server, backup server, download client, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, surveillance station, DLNA Media Server, DHCP client, e-mail notification, cloud backup, VPN Server, Apple AirPlay
- Encryption Algorithm
- FIPS 140-2, 256-bit AES, AES-NI
- DLNA CERTIFIED, UPnP
Security DVR
- 40
- Expansion Bays
- 6 (total) / 6 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 0 (free) x SO-DIMM 204-pin , 1 x PCI Express 2.0 x2
- 2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 3.0 - Type A , 2 x microphone - mini-jack , 2 x HDMI output , 1 x audio out , 1 x USB - Type C
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), built-in 2 cooling fans
- Security Slot Type
- Kensington security slot
- Included Accessories
- Remote control
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 40.33 Watt
- Power Provided
- 120 Watt
- QNAP QTS 4.3
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
