In response to the coming era of Internet of Things (IoT), the TS-653A innovatively supports the open-source Linux platform as a gateway for IoT solutions to other smart devices. The TS-653A allows users to directly utilize various feature-rich Liunx apps, enjoying a private cloud combining storage and IoT applications, and professional developers can develop and run IoT applications directly on the TS-653A. The secure, reliable TS-653A is packed with business-critical features such as Volume/LUN Snapshot - allowing files/folders to revert to a previous state in case of any corruption or file-loss. The TS-653A is powered by the latest quad-core Intel Celeron processor which allows users to enjoy 4K (H.264) video playback and 1080p/4K video real-time transcoding directly from the TS-653A to an HD/4K display.
- QNAP TS-653A - NAS server - 36 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 36 TB
- Installed Devices / Modules Qty
- 6 (installed) / 6 (max)
- 25.7 cm x 23.5 cm x 17.5 cm
- Processor
- 1 x Intel Celeron N3150 1.6 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
- Hard Drive
- 6 x 6 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.2
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2003, Apple MacOS X or later, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 36 TB
- 25.7 cm
- 23.5 cm
- 17.5 cm
- Built-in Devices
- Status LCD, led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 8 GB (installed) / 8 GB (supported) - DDR3L
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
- HDD - hot-swap
- Capacity
- 6 x 6 TB
- Data Link Protocol
- TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
- Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, video server, firmware upgradable, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay
- Encryption Algorithm
- SSL, TLS, FIPS 140-2, 256-bit AES
- DLNA CERTIFIED, UPnP
- Expansion Bays
- 6 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 0 (free) x SO-DIMM 204-pin
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x audio in - 6.3mm jack , 4 x USB 3.0 - Type A , 2 x HDMI output , 1 x audio out - mini-jack
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), remote control, built-in cooling fan
- FIPS 140-2
- Included Accessories
- Remote control
- Power Device
- Internal power supply
- Voltage Required
- 51.16 Watt
- Power Provided
- 240 Watt
- QNAP QTS 4.2
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
