Your basket is empty
QNAP TS-463U-RP-4G/12TB-RED PRO Rackmount NAS
Quicklinx: C2JFWS00 Mfr#: TS-463U-RP-4G/12TB-RED PRO
The TS-463U-RP is a powerful network storage system powered by a high-performance processor. It provides 10GbE to optimize ROI, and doubles the encrypted file transfer performance with the AES-NI hardware-accelerated encryption engine. The TS-463U-RP provides versatile all-in-one server functionalities as well as advanced features including Virtualization Station, which allows users to run VMs on the same device. The TS-463U-RP is designed for small and medium-sized businesses looking for backup, restoration, private cloud, storage for virtualization and to future-proof their IT infrastructure for 10GbE networks.
QNAP TS-463U-RP - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet / 10Gbps SFP+
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
12 TB
4 (installed) / 4 (max)
43.9 cm x 49.9 cm x 4.4 cm
7.63 kg
1 x AMD G-Series 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 5 hot spare, 6 hot spare, 10 hot spare
Hard Drive
4 x 3 TB
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
4 GB
Power Redundancy
Storage Operating System
QNAP QTS 4.2
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 1U
12 TB
43.9 cm
49.9 cm
4.4 cm
7.63 kg
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 16 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
HDD - hot-swap
4 x 3 TB
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, print server, IPv6 support, backup server, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, iTunes server, Jumbo Frames support, DHCP server, FTP server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, SFTP client
Encryption Algorithm
SSL, 256-bit AES
UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCI Express 2.0
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 3 x USB 2.0 - Type A , 1 x Ethernet 10Gb - SFP+
2 x network cable
Built-in 2 cooling fans
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
250 Watt
QNAP QTS 4.2
5 - 95%
