Your basket is empty
QNAP TS-453MINI-8G/12TB-RED (4 x 3TB WD Red HDDs) 4 Bay Desktop
Quicklinx: BSQXWS00 Mfr#: TS-453MINI-8G/12TB-RED
  • Celeron
Feel surprised that how a NAS can be extraordinary, like the TS-453mini! The glossy TS-453mini features a stylish vertical design that takes up less desktop space, suitable for offices or even study rooms at home. It houses a quiet internal compact exhaust that helps dissipate heat, delivers less noise and reduces dust. With the tool-less design, you can easily remove the TS-453mini's magnetic top cover to add or replace hot-swappable 3.5" hard drives. Upgrading the RAM of a NAS has also never been easier with a conveniently accessible cover at the bottom.
The aesthetically-designed skyline LED indicator will flash a blue light for system S3 sleep mode notification. Besides, you can adjust the brightness of all system indicators and also schedule the system to automatically dim the LEDs at certain times when needed.
QNAP TS-453mini - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
12 TB
4 (installed) / 4 (max)
15.1 cm x 20 cm x 21 cm
1 x Intel Celeron 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
4 x 3 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
24
RAM
8 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Microsoft Windows XP or later, Apple MacOS X or later, Microsoft Windows Server 2003 or later
NAS server
Host Connectivity
Gigabit Ethernet
12 TB
15.1 cm
20 cm
21 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD
4 x 3 TB
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, proxy server, web server, backup server, download client, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, surveillance station, DLNA Media Server, DHCP client, e-mail notification, cloud backup, VPN Server, Apple AirPlay
Encryption Algorithm
FIPS 140-2, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
24
Expansion Bays
4 (total) / 0 (free) - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x HDMI output - Type A
2 x network cable
Remote control, built-in cooling fan
External power adapter
AC 120/230 V
Power Provided
90 Watt
QNAP QTS 4.1
35 °C
5 - 95% (non-condensing)
