Product
QNAP TS-453BU-8G 4 Bay NAS Rack Mountable
Quicklinx: D89QWS00 Mfr#: TS-453BU-8G
  • Celeron
The TS-453BU is a 1U rackmount NAS that easily fits into a standard 19-inch rack, providing an ideal storage solution in the server room for small and medium businesses. The TS-453BU comes with a PCIe slot for boosting potential applications: the QNAP QM2 expansion card can be installed to add an M.2 SSD cache/10GbE connectivity, a compatible wireless card can be installed to use the TS-453 BU as a wireless access point, and a USB 3.1 10Gbps card can be added for easier backup to/from multiple external storage.
  • High performance
    Powered by an excellent processor with energy-efficient memory, coupled with the support of SATA, 4 Gigabit LAN ports and HDMI output, the TS-453 is a powerful NAS, that delivers fast read and write speeds. The TS-453 can also automatically increase the processor's clock rate when needed for CPU-intensive tasks. The TS-453's fast encryption and decryption performance provides high transfer speeds with AES 256-bit volume encryption, boosting system performance and security while ensuring the safety of sensitive business data, stored in the TS-453. When installed with the dual-band Wi-Fi network card, the TS-453 can offer remarkably high speeds for transferring large amount of files and streaming bandwidth-consuming multimedia.
  • Comprehensive security solutions
    In open-network environments, business data may be exposed in a potential hack. The TS-453 provides numerous security solutions, such as encrypted access, IP blocking, and more. IT administrators can also control the access rights of each user to different folders, preventing unauthorized access to important files. The TS-453 is validated with military-level AES 256-bit encryption, preventing sensitive business data from unauthorized access and breach, even if the hard drives or the entire system were stolen.
  • Real-time and offline HD video transcoding
    The TS-453 delivers superior real-time Full HD video transcoding to convert videos to formats, that can be smoothly played on PCs, mobile devices and Smart TVs. It allows for a few devices to simultaneously view different videos, stored on the TS-453 with on-the-fly hardware-accelerated transcoding. The TS-453 allows you to enjoy instant videos on multiple devices - even those, that lack computing power or have limited file format support - without the need for complicated and time-consuming file conversion. With the benefit of offline transcoding, if you can only connect to an Internet connection with limited/restricted bandwidth, you can still enjoy smooth videos by selecting a pre-rendered lower resolution to play the videos without affecting the TS-453's system performance, running other applications. This also allows more people to play videos via streaming. The TS-453 also allows you to set a dedicated folder for automatic video transcoding.
QNAP TS-453BU - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
0 GB
0 (installed) / 4 (max)
43.9 cm x 49.9 cm x 4.4 cm
7.63 kg
1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
10Mb LAN, 100Mb LAN, GigE
RAM
8 GB
Storage Operating System
QNAP QTS 4.3
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
0 GB
43.9 cm
49.9 cm
4.4 cm
7.63 kg
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.3 GHz
RAM
8 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
4 GB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
NAT support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, Spanning Tree Protocol (STP) support, download client, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, Apple AirPlay, event notification, push notification, Chromecast support
Encryption Algorithm
SSL, FIPS 140-2, 256-bit AES
UPnP
Expansion Bays
4 (total) / 4 (free) x hot-swap
Expansion Slots
2 (total) / 0 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCI Express 2.0 x2
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 1 x HDMI output
2 x network cable
Audible alarm, wake on LAN, built-in 2 cooling fans
Internal power supply
Installed Qty
1
Max Supported Qty
1
31.5 Watt
Power Provided
250 Watt
QNAP QTS 4.3
0 - 95%
Sound Emission
38.6 dBA
