QNAP TS-453BE-4G 4GB 4-Bay Desktop NAS
Quicklinx: DFDXWS00 Mfr#: TS-453BE-4G
Capacity: 0GB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
Type: 4-Bay
  • Celeron
£493.48 ex VAT
£592.17 inc VAT
The TS-453Be features a simple physical design that can easily fit into office and home environments. It provides a PCIe port that can boost its functionality. The TS-453Be also supports dual-channel 4K H.264/H.265 processing to provide a smooth media viewing experience on all connected devices.
  • Extend NAS functionalities with the PCIe slot
    With PCIe expansion, the TS-453Be provides flexibility in extending NAS functionality and potential applications.
  • Protect data with snapshots
    Snapshots help protect your data by fully recording the NAS system state and metadata. If a file is accidentally deleted or modified, you can use snapshots to quickly restore the file to its previously-recorded state.
  • Supports 360-degree panorama photos and videos
    QNAP NAS now supports the popular 360-degree panorama recording format! By clicking the 360-degree panorama display button, these photos and videos will be displayed as 360-degree panorama media files.
  • Flexible and economical storage expansion
    You need an easy solution to increase storage capacity when running out of space. QNAP provides several ways to expand your NAS storage as needed to accommodate data and business growth.
QNAP TS-453Be-4G - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
0 (installed) / 4 (max)
17 cm x 22.6 cm x 16.8 cm
2.33 kg
1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, GigE
RAM
4 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.3.4
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
17 cm
22.6 cm
16.8 cm
2.33 kg
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.3 GHz
RAM
(supported) 4 GB (installed) / 8 GB (supported) - DDR3L
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, FTP, DHCP, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Wake on LAN (WOL), iTunes server, Jumbo Frames support, DHCP server, FTP server, teaming support, DLNA Media Server, DHCP client, 4K resolution support, VPN Server, VPN client, port trunking, FXP support, RTRR server, RTRR client
Encryption Algorithm
SSL, FIPS 140-2, 256-bit AES, AES-NI
DLNA CERTIFIED
Security DVR
Compression Format
H.264, H.265
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 2.0 x2
2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 3.0 - Type A , 2 x microphone - mini-jack , 2 x HDMI output - Type A , 1 x audio out - mini-jack
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
Security Slot Type
Kensington security slot
Screws
External power adapter
AC 120/230 V
30.04 Watt
Power Provided
90 Watt
QNAP QTS 4.3.4
5 - 95% (non-condensing)
Capacity: 0GB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Type: 4-Bay
Brand: QNAP
Price Range Ex VAT: 300 - 500
