QNAP TS-453Be-2G 2GB 4-Bay Desktop NAS - Diskless
Quicklinx: DFF1WS00 Mfr#: TS-453BE-2G
Interface: Fast Ethernet, Ethernet, Gigabit Ethernet
Capacity: 0GB
Type: 4-Bay
  • Celeron
£426.70 ex VAT
£512.04 inc VAT
The TS-453Be features a simple physical design that can easily fit into office and home environments. It provides a PCIe port that can boost its functionality: a QNAP QM2 expansion card can be installed to add M.2 SSD caching/10GbE connectivity and support for Qtier auto-tiering technology, or a compatible wireless card can be installed to use the TS-453Be as a wireless access point. The TS-453Be also supports dual-channel 4K H.264/H.265 processing to provide a smooth media viewing experience on all connected devices. In addition, a wide range of productivity tools are available for use on the TS-453Be to improve work efficiency for media creators or creative professionals, while also enriching their multimedia experience.
PCIe
The PCIe port supports installing a 10GbE network card, a QM2 dual-port M.2 SSD/10GbE card, a USB 3.1 10Gbps card or a compatible PCIe wireless adapter.
4K
4K media playback and online transcoding; multimedia viewing on HDTV via HDMI output.
Recovery
Snapshots fully record the system status and data. If files are accidentally deleted or modified, you can quickly restore the previously-recorded data.
Hybrid Backup Sync
Hybrid Backup Sync consolidates backup and sync tasks into a single app.
Secure Cloud
Secure private cloud solution with high storage scalability.
Multi-OS
Supports containerized applications and hosting multi-OS virtual machines.
  • Extend NAS functionalities with the PCIe slot
    With PCIe expansion, the TS-453Be provides flexibility in extending NAS functionality and potential applications. Install a QNAP QM2 card to provide M.2 SSD caching/10GbE connectivity, or use the TS-453Be as a wireless access point by installing a compatible wireless network card, or boost the USB connectivity of the TS-453Be by installing a USB 3.1 10 Gbps card.
  • Powerful CPU with AES-NI encryption
    Powered by an excellent processor, dual Gigabit LAN ports, and supporting SATA 6 Gb/s hard drives, the TS-453Be provides dependable performance of up to 225 MB/s read/write speeds. The TS-453Be features Intel AES-NI hardware-accelerated encryption to drive transfer speeds of up to 225 MB/s with AES 256-bit encryption for both full NAS volumes and shared folders, boosting system performance while ensuring the security of sensitive data stored in the TS-453Be.
  • Real-time video transcoding
    Featuring advanced Intel HD Graphics, the TS-453Be supports dual-channel 4K H.264/H.265 hardware decoding and real-time transcoding, allowing you to convert videos to universal file formats that can be smoothly played on multiple devices. Therefore, you can easily share movies and videos stored on your NAS with family and friends for their enjoyment on a range of devices.
QNAP TS-453Be-2G - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 4 (max)
17 cm x 22.6 cm x 16.8 cm
2.33 kg ()
1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
RAM
2 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.3.4
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
17 cm
22.6 cm
16.8 cm
2.33 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.3 GHz
RAM
2 GB (installed) / 8 GB (supported) - DDR3L
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, FTP, DHCP, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Wake on LAN (WOL), iTunes server, Jumbo Frames support, DHCP server, FTP server, teaming support, DLNA Media Server, DHCP client, 4K resolution support, VPN Server, VPN client, port trunking, FXP support, RTRR server, RTRR client
Encryption Algorithm
SSL, FIPS 140-2, 256-bit AES, AES-NI
DLNA CERTIFIED
Security DVR
Compression Format
H.264, H.265
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 2.0 x2
2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 3.0 - Type A , 2 x microphone - mini-jack , 2 x HDMI output - Type A , 1 x audio out - mini-jack
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
Security Slot Type
Kensington security slot
Screws
External power adapter
AC 120/230 V
30.04 Watt
Power Provided
90 Watt
QNAP QTS 4.3.4
5 - 95% (non-condensing)
Capacity: 0GB
Interface: Ethernet
Interface: Gigabit Ethernet
Type: 4-Bay
Brand: QNAP
