Your basket is empty
QNAP TS-451U-1G 8TB-RED 4Bay Rackmount NAS
Quicklinx: B50XWS00 Mfr#: TS-451U-1G/8TB-RED
  • Celeron
The TS-451U, featuring the easy-to-use QTS operating system, is an affordable, reliable and scalable 4-bay rackmount NAS designed for small offices and home offices, assisting in daily operations including file storage, backup, sharing, synchronization, and more. The TS-451U supports SATA 6Gb/s drives and delivers high performance with persistent throughput, providing a comprehensive storage solution for users to build a private cloud to access their data easily.
QNAP TS-451U - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
8 TB
4 (installed) / 4 (max)
43.9 cm x 49.9 cm x 4.4 cm
7.63 kg
1 x Intel Celeron 2.41 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 5 hot spare
Hard Drive
4 x 2 TB
10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows 7 / Windows 8 (64 bits), Microsoft Windows Server 2012 R2
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
8 TB
43.9 cm
49.9 cm
4.4 cm
7.63 kg
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare
Hard Drive
HDD - hot-swap
4 x 2 TB
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, SMB, DDNS
Remote Management Protocol
SNMP 2, SNMP, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, proxy server, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Jumbo Frames support, DHCP server, SMS alert, IPv4 support, surveillance station, Apple Time Machine compatible, DHCP client, audible alarm notification, WebDAV server, cloud backup, SNMP support
Encryption Algorithm
AES, SSL, 128-bit AES, 256-bit AES
UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000 - RJ-45 , 5 x USB 3.0 - Type A , 1 x HDMI output
2 x network cable
Built-in 2 cooling fans, VPN support
FIPS 140-2
Mounting kit
Internal power supply
38.01 Watt
Power Provided
250 Watt
QNAP QTS 4.1
0 - 95%
