QNAP TS-410U/4TB NAS
Quicklinx: 79KQWS00 Mfr#: TS-410U/4TB
The 4-bay, 1U rack-mounted TS-410U Turbo NAS is the perfect storage solution with best price performance ratio for SMB and workgroups who need a network attached storage (NAS) server with solid performance, low power consumption, high reliability, and excellent overall value. The Turbo NAS can be easily installed in the server room with rack slide rail kit and efficiently managed by IT personnel over the local network or the Internet. The Turbo NAS is more than a simple networked storage server. It is capable of being a stand-alone download server, centralized network backup, website hosting, network surveillance, and much more.
The Turbo NAS incorporates a Marvell CPU and DDRII memory. The Turbo NAS supports advanced NAS and iSCSI applications to provide a low-cost, highly flexible and efficient IP SAN solution. Up to 8 iSCSI targets can be created on the NAS for storage expansion and a central backup destination for computers and servers. The powerful built-in virtual disk drive (VDD) function allows the Turbo NAS to connect other iSCSI targets on the network to "virtually" expand its capacity.
The Turbo NAS supports RAID 0/1/5/6/5+spare, single and JBOD disk configurations. The unique online RAID capacity expansion and online RAID level migration features allow the administrator to expand the storage capacity of the RAID configuration and upgrade the RAID level without turning off the server. A built-in RAID recovery feature is offered to secure the server data against accidental removal of the hard drives.
  • Failover
    The dual LAN ports can be configured as failover which allows the NAS server to sustain the failure of one network port to provide continuous services.
  • Multi-IP setting
    The TS-410U can be deployed with two IP settings for sharing among different workgroups in two different subnets.
  • Advanced RAID management with hot-swap design
    The NAS offers advanced RAID 0, 1, 5, 6, 5 + hot spare, Single, and JBOD disk configurations. It also supports hot-swap design that a failed drive can be replaced by hot swapping without turning off the server.
  • Online RAID capacity expansion
    The storage capacity of a RAID configuration can be expanded by replacing the hard drives with larger ones. All the data will be kept and seamlessly moved to the newly installed hard drives. There is no need to turn off the server during the process.
  • Online RAID level migration
    You can upgrade the disk configuration to higher RAID level with the data retained. There is no need to turn off the server during the process.
  • Virtual Disk Drive (VDD) adds flexibility to storage expansion along with ease of management
    The unique "Virtual Disk Drive" adds flexibility to expand the capacity of NAS. By using the built-in iSCSI initiator, the NAS can connect to other iSCSI targets on the network and turn them into virtual disks, which become multiple single volumes on the NAS.
  • Flexible built-in iSCSI target service
    With the built-in iSCSI target feature, the NAS can be an ideal solution for backup or storage expansion. Small business and SMB users can easily create dedicated virtual drives on the NAS for their PCs or existing servers. The iSCSI drives on the NAS can be formatted as file system and used as local drives.
  • S.M.A.R.T. and advanced HDD Health Scanning (HHS)
    The NAS supports Hard Disk Drive S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) for monitoring the hard drive status. Moreover, the NAS is embedded with HHS technology which supports disk checking and bad blocks scanning.
  • Encrypted remote replication
    The data on the NAS can be backed up to or from another Turbo NAS over the network securely.
  • Ease of user and share folder management
    The NAS supports batch creation of users and share folders to save the time and effort of the server manager in account and folder creation. For the security of Windows network environment, server managers can hide or show network share folders.
  • Hard disk standby
    You can configure the hard disks to enter standby mode if there is no disk access within the specified period.
  • Schedule power on/off
    The flexible schedule power on/off feature is now provided on the NAS for IT administrators to manage the NAS server's up time according to the working hours. You can set the time for automatic system power on, power off, or restart on any days of the week.
  • UPS support
    The TS-410U supports the majority of USB UPS devices which enables the users to store the data in time and avoid critical data loss when power outage occurs during data transfer. It also supports advanced stand-by mode setting that you can set the time for the server to enter standby mode when an abnormal AC power supply is detected. When the power resumes, the server resumes to the operation status before the power outage.
  • Smart fan
    The fan rotation speed is automatically adjusted according to the server's temperature. You can also define the system temperatures to trigger high speed or low speed rotation of the fan. By manually setting the fan rotation speed, the fan will rotate at the defined speed continuously.
  • Instant SMS/email alert
    You can configure the SMTP server and SMSC server settings on the NAS in order to receive instant system warning or error messages by email or SMS.
  • SNMP (Simple Network Management Protocol)
    Simple Network Management Protocol (SNMP) is widely used in network management systems to monitor network attached devices (e.g. NAS). You can set up SNMP trap for alerting via SNMP and there can be up to 3 SNMP trap addresses. Besides, you can also choose the system event log level in SNMP.
  • SSL secure certificate
    The administrator can upload a secure certificate and an RSA private key in X.509PEM format issued by a trusted provider in order to allow the users to access the NAS by secure SSL login.
QNAP TS-410U Turbo NAS - NAS server - 4 TB
NAS server
Host Connectivity
USB 2.0 / Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
4 TB
0 (installed) / 4 (max)
43.9 cm x 48.3 cm x 4.4 cm
11.1 kg ()
1 x Marvell 6281 800 MHz
Storage Controller
RAID SATA 3Gb/s RAID 0, 1, 5, 6, JBOD, 5 hot spare
Hard Drive
4 x 1 TB SATA 3Gb/s
Network adapter - integrated - 1GbE, USB 2.0
RAM
512 MB
Storage Operating System
Linux
UNIX, Linux, Apple MacOS X, Microsoft Windows 2003, Microsoft Windows Vista / 2000 / XP
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 1U
4 TB
43.9 cm
48.3 cm
4.4 cm
11.1 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
RAM
512 MB
Flash Memory Installed
16 MB Flash
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap - 2.5" / 3.5" shared
4 x 1 TB
Interface Type
SATA 3Gb/s
1GbE, USB 2.0
Network / Transport Protocol
TCP/IP, AppleTalk, NTP, iSCSI, SMTP, FTP, DHCP, Bonjour
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, FTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Dynamic IP address assignment, NAT support, trunking, load balancing, dynamic DNS server, E-mail alert, print server, firmware upgradable, MySQL server, web server, event log, ACL support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server
DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
4 x USB 2.0 - Type A , 2 x eSATA 3Gb/s , 2 x Ethernet 1000Base-T - RJ-45
2 x network cable
Security Slot Type
Kensington security slot
External power adapter
Power Provided
250 Watt
Linux
Software Included
Drivers & Utilities
0 - 95%
