With the growing popularity of smartphones and cameras, a staggering amount of digital media is being created and downloaded every day. This media is also becoming increasingly larger in size, with Full HD movies available to download for mobile devices and 4K on the horizon for HDTVs and download services. This rise in file size makes it impossible for limited mobile devices to store large amounts of media, and also forces users to sacrifice quality for storage space. With the improved TS, QNAP offers customers a NAS with a large and scalable storage solution with a powerful processor and HDMI connectivity for home entertainment and QNAP's unique accelerated transcoding, that allows mobile devices to enjoy media with optimized resolutions and saving their local storage space. The TS also features QNAP's exclusive QvPC technology, that allows you to use a TS model as a PC by simply plugging in a keyboard, mouse and HDMI monitor - greatly extending its functionality and providing even more value for home users.
- QNAP TS-251A - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 10.2 cm x 22.5 cm x 16.85 cm
- 1.28 kg ()
- Processor
- 1 x Intel Celeron N3060 1.6 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
- Card Reader
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 32
- RAM
- 4 GB
- Power
- AC 120/230 V
- Storage Operating System
- QNAP QTS 4.2
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 10.2 cm
- 22.5 cm
- 16.85 cm
- 1.28 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 4 GB (installed) / 8 GB (supported) - DDR3L
- Flash Memory Installed
- 4 GB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
- Data Link Protocol
- TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
- Hardware encryption, trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR)
- Encryption Algorithm
- SSL, TLS, FIPS 140-2, 256-bit AES
- UPnP
Security DVR
- 32
- Expansion Bays
- 2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 0 (free) x SO-DIMM 204-pin
- 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x micro-USB 3.0 - Type B , 1 x HDMI output , 1 x microphone - mini-jack , 1 x audio out - mini-jack
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), audible alarm, remote control, built-in cooling fan
- Security Slot Type
- Kensington security slot
- FIPS 140-2, AES-256
- Included Accessories
- Remote control
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Power Provided
- 65 Watt
- QNAP QTS 4.2
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Sound Emission
- 18.3 dBA
