QNAP TS-231P 2 Bay NAS
Quicklinx: CK11WS00 Mfr#: TS-231P
The TS-231P is a powerful yet easy-to-use network storage center for backup, synchronization, remote access, and home entertainment with many feature-rich apps available, including Notes Station (create digital notes on a secure private cloud and share with colleagues and friends), QmailAgent (centralize email account management and back up emails), and Qcontactz (centrally store and manage contact information). All these apps (and more) are available at no extra cost. The dual-core TS-231P features three USB 3.0 ports and dual LAN ports, delivering outstanding multitasking performance to enhance your productivity & digital life and offering an ideal storage and backup center as a secure private cloud.
  • Dual-core processor delivers high performance
    Equipped with an AnnapurnaLabs, an Amazon company Alpine AL-212 dual-core 1.7 GHz Cortex-A15 processor and 1GB DDR3 RAM, the TS-231P is a high-performance NAS for home, workgroups and SOHO users providing outstanding performance of up to 224 MB/s read & 176 MB/s write throughput. The TS-231P's enhanced hardware-based encryption and decryption engine provides transfer speeds of over 179 MB/s with AES 256-bit full NAS volume encryption, boosting system performance & security while ensuring the safety of sensitive personal data stored in the NAS. When used with a compatible 802.11ac or dual-band 2.4GHz/5GHz 802.11n USB Wi-Fi adapter, the TS-231P becomes an ideal media center with remarkably high speeds for transferring a large amount of files and streaming bandwidth-intensive multimedia.
  • High efficiency with dual LAN support
    The TS-231P supports multiple port-trunking modes, enabling administrators to set up link aggregation to increase total data transmission potential. Failover and dual IP are also supported to ensure continuous system operations. Supported port-trunking modes include: Balance-rr (Round-Robin), Active Backup, Balance XOR, Broadcast, IEEE 802.3ad, Balance-tlb (Adaptive Transmit Load Balancing) and Balance-alb (Adaptive Load Balancing).
  • Enhance productivity with multiple USB 3.0 ports
    Equipped with three SuperSpeed USB 3.0 ports, the TS-231P allows you to flexibly arrange tasks with a wide range of external devices without interrupting your current workflow. You can back up files to USB drives, access data stored on SD cards via USB card readers, share up to 3 printers via network, and connect to a UPS to ensure a continual power supply.
  • QTS - simple and efficient
    Thanks to the intuitive user interface of QTS, your NAS experience is smarter, smoother and spectacular. Its modern flat design streamlines loading times, and the intelligent desktop allows you to find desired functions quickly, create desktop shortcuts or group shortcuts, monitor important system information on a real-time basis, and open multiple application windows to run multiple tasks concurrently, bringing greater working efficiency. QTS breaks the barriers of devices, platforms and geography to bring optimized cloud experiences to you.
  • Create digital notes on your private cloud
    The revamped Notes Station features an optimized interface for a smoother user experience. Notes Station allows users to collectively write documents and helps users to track changes by retaining the revision history of documents. Notes Station provides useful image-editing tools, helping you create well-designed documents. You can also create sharing links to share documents in real time. Documents can also be encrypted to prevent unauthorized access, and snapshot backup is provided to retain different versions of documents from different time periods. With its importing/exporting and full-site backup functions, Notes Station supports backing up your documents to local or remote QNAP NAS.
  • QmailAgent - a mailroom center for your private cloud
    QmailAgent is an online email client that helps you manage multiple email accounts, allowing you to access all of your emails and to easily switch between different accounts. It provides complete functionality for composing, reading and organizing emails. You can even attach files, photos and documents from the TS-231P when composing emails. iOS and Android users can use the QmailClient app to quickly check multiple email accounts with mobile devices, and to browse & send emails using the QmailAgent on their TS-231P. You can use QmailAgent together with Qsirch, which supports searching through the .eml files stored on the TS-231P, to make searching through and managing massive amounts of emails much easier.
  • Qcontactz - easily manage huge amounts of contacts on the NAS
    Qcontactz with the high-capacity TS-231P helps you centrally store and manage contact information for colleagues, business partners, families, and friends. Other features include: importing from Google accounts, importing/exporting CSV or vCARD 3.0 files, automatic identification of frequently-used contacts, encryption for sensitive/confidential contact information, smart searching, and more. Qcontactz offers snapshot backups that enable you to revert to a previous version of your contacts list according to your needs. A companion app for Android phones and iPhone is also available for easy access to contacts. Qcontactz can also be used with QmailAgent to create the perfect email workflow environment.
  • Well-rounded backup solutions to secure data
    The TS-231P is a comprehensive centralized backup center for multiple files. The front panel USB port features a one-touch-copy function for you to instantly back up data on USB drives to the TS-231P or alternatively to back up data from the TS-231P to USB drives. You can use QNAP NetBak Replicator to back up files on Windows (including Outlook email archiving) to the TS-231P, or use Time Machine for Mac data backup. A wide range of third-party backup software (such as Acronis True Image and Symantec Backup Exec) are also supported to facilitate system backup and restoration.
  • Cross-platform file sharing, centralized data storage
    The TS-231P supports SMB/CIFS, NFS, and AFP protocols for file sharing across Windows, Mac, Linux /UNIX networks. Data, logs and ISO images of CDs and DVDs can be centrally stored on the TS-231P.
  • Manage your files via the Internet
    File Station brings conventional desktop-style file operations to web browsers, allowing you to upload, download, and manage files on your TS-231P wherever there is an internet connection. Supporting file extraction, folder creation, and smart search for files and folders, File Station also allows you to easily share files via unique URLs protected with reliable security features, SSL and password options. You can even directly browse and transfer files between the TS-231P and public cloud services like Google Drive, Dropbox, Microsoft OneDrive, Box, Yandex Disk and Amazon Drive, open office files directly with a Google Chrome office extension, and also view your files on Google Docs or Office Online.
QNAP TS-231P - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 2 (max)
10.2 cm x 22.5 cm x 16.85 cm
1.28 kg ()
1 x Annapurna Labs Alpine AL-212 1.7 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
25
RAM
1 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
10.2 cm
22.5 cm
16.85 cm
1.28 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS, SFTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, web server, backup server, download client, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, reset button, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Wi-Fi USB dongle support, Real-time Remote Replication (RTRR), Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support
Encryption Algorithm
AES, SSL, TLS, 128-bit AES, 256-bit AES
UPnP
Security DVR
25
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, wake on LAN, built-in cooling fan, AirPlay, scheduled power on/off
Security Slot Type
Kensington security slot
External power adapter
AC 120/230 V
Power Provided
65 Watt
QNAP QTS 4.2
5 - 95% (non-condensing)
Sound Emission
19.2 dBA
