The TS-231+ is a powerful yet easy-to-use network storage center for backup, synchronization, remote access, and home entertainment. With the Notes Station, you can easily create digital notes on a secure private cloud and share with colleagues and friends at no extra cost. Powered by an advanced ARM dual-core processor, the TS-231+ delivers outstanding multitasking performance as a SOHO NAS featuring three USB 3.0 and dual LAN ports. See how TS-231+ can enhance your working productivity & digital life.
Dual-core processor delivers high performance
Equipped with powerful yet energy-efficient dual-core processor, the TS-231+ is a high-performance NAS for workgroups and SOHO providing outstanding performance. The TS-231+'s enhanced hardware-based encryption and decryption engine provides transfer speeds of over 162 MB/s with AES-256 bit full NAS volume encryption, boosting system performance & security while ensuring the safety of sensitive personal data stored in the TS-231+. You can also use the TS-231+ as a multimedia center to watch media content while downloading or backing up files without impacting the TS-231+'s performance. -
High efficiency with dual LAN support
The TS-231+ supports multiple port-trunking modes, enabling IT administrators to set up link aggregation to increase total data transmission capability. Failover and dual IP are also supported to ensure continuous system operations. -
QTS - simple and efficient
Thanks to QTS intuitive user interface, system operations of the TS-231+ are smooth and handy. Its intelligent desktop allows you to find desired functions quickly, create desktop shortcuts or group shortcuts, monitor important system information on a real-time basis, and open multiple application windows to run multiple tasks concurrently, bringing greater operating efficiency. -
Enhance productivity with multiple USB 3.0 ports
Equipped with three SuperSpeed USB 3.0 ports, the TS-231+ allows you to flexibly arrange tasks with a wide range of external devices without interrupting your current workflow. You can back up files to USB drives, access data stored on SD cards via USB card readers, share up to 3 printers via network, and connect to a UPS to ensure a continual power supply. -
Well-rounded backup solutions to secure data
The front panel USB port features a one-touch-copy function for you to instantly back up data on external drives to the TS-231+ or alternatively to back up data from the TS-231+ to external drives. QNAP's NetBak Replicator supports real-time and scheduled data backup for Windows and Mac OS X users can use Time Machine to effortlessly back up data to the TS-231+. A wide range of third-party backup software such as Acronis True Image and Symantec Backup Exec are also supported.
- QNAP TS-231+ - NAS server - 16 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 16 TB
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 10.2 cm x 22.5 cm x 16.85 cm
- 1.28 kg ()
- Processor
- 1 x ARM Cortex-A15 1.4 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 8 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 1 GB
- Power
- AC 120/230 V
- Storage Operating System
- QNAP QTS 4.1
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows 2003, Microsoft Windows Vista / XP, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits)
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 16 TB
- 10.2 cm
- 22.5 cm
- 16.85 cm
- 1.28 kg ()
- Built-in Devices
- Print server
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 1 GB DDR3
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 2 x 8 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Apple File Protocol (AFP), HTTP, Web-based Distributed Authoring and Versioning (WebDAV)
- LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, backup server, Access Control List (ACL) support, iTunes server, DHCP server, SMS alert, IPv4 support, surveillance station, DLNA Media Server, DHCP client, VPN Server, Apple AirPlay
- Encryption Algorithm
- SSL, FIPS 140-2, 256-bit AES
- DLNA CERTIFIED, UPnP
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan, AirPlay, scheduled power on/off
- Security Slot Type
- Kensington security slot
- VCCI, C-Tick, BSMI, FCC
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 16.01 Watt
- Power Provided
- 60 Watt
- QNAP QTS 4.1
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
