Your basket is empty
QNAP TS-212P 12TB-Red 2 Bay NAS
Quicklinx: 9XL1WS00 Mfr#: TS-212P/12TB-RED
  • Windows 8 (32/64 bits)
The TS-212P is a powerful yet easy to use network storage center for data storage, backup, synchronization, remote access, and home entertainment. As your personal cloud, you will always be connected to your files and your files are always under your control.
The TS-212P is high-performance cross-platform storage with many friendly storage and backup options that centralizes and protects all your important files on one single device.
The TS-212P acts as your photo vault for you to back up your favorite photos. The Photo Station makes photo sharing simple, and you can designate your own access right controls. Simply upload your photos to the TS-212P to create and organize your photo albums through a web browser to share with your family and friends. Your mobile devices are useful too, with the Qfile mobile app in your iOS or Android devices you can instantly upload photos to the TS-212P.
QNAP TS-212P Turbo NAS - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
12 TB
2 (installed) / 2 (max)
8.5 cm x 21.84 cm x 16.55 cm
Marvell 88F6282 1.6 GHz
Storage Controller
SATA SATA 3Gb/s
Hard Drive
2 x 6 TB
10Mb LAN, 100Mb LAN, GigE
RAM
512 MB
AC 120/230 V
Storage Operating System
QNAP Turbo NAS System 4.0
UNIX, Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
12 TB
8.5 cm
21.84 cm
16.55 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
RAM
512 MB DDR3
Flash Memory Installed
16 MB
Storage Controller
SATA
Interface Type
SATA 3Gb/s
Hard Drive
HDD - 3.5"
2 x 6 TB
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, IP address filtering, firmware upgradable, proxy server, MySQL server, web server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, RADIUS support, SSH support, iTunes server, DHCP server, FTP server, SMS alert, BitTorrent Client, IPv4 support, surveillance station, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, anti-virus protection
UPnP
Expansion Bays
2 (total) / 0 (free) x internal - 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A
1 x network cable , 1 x Serial ATA cable , 1 x Serial ATA power adapter
Audible alarm, wake on LAN, K-lock security slot, built-in cooling fan
External power adapter
AC 120/230 V
13 Watt
Power Provided
60 Watt
5 - 95% (non-condensing)
