Powered by AMD's powerful Ryzen processor, the TS-1677XU-RP is capable of boosting virtual machine performance with up to 8 cores/16 threads and Turbo Core up to 4.1 GHz. Four PCIe Gen.3 slots provides expandability to provide more potential applications and functionality for the TS-1677XU-RP. The TS-1677XU-RP also features a redundant power supply to ensure maximum system uptime.
Top-class hardware engineering with high I/O expandability
The hardware design of the TS-1677XU-RP provides exceptional system performance and expandability to fulfill diverse application requirements. -
Absolute performance with AMD Ryzen and up to 64GB RAM
Powered by a high-performance AMD Ryzen 7 2700, AMD Ryzen 5 2600 or AMD Ryzen 3 1200 processor with AES-NI encryption acceleration and up to 64GB DDR4 RAM, the TS-1677XU-RP delivers aggressive yet power-smart performance to meet your multitasking demands. For resource-demanding business applications such as VDI, R&D, private cloud, and server virtualization, look no further than the TS-1677XU-RP. -
Dual-channel Memory to deliver power-smart performance
The TS-1677XU-RP supports dual-channel DDR-4 memory and four Long-DIMM slots. When using paired memory modules, the TS-1677XU-RP can leverage the power of dual-channel architecture to boost performance. You also customize the memory configuration (supports up to 64GB RAM) of the TS-1677XU-RP, making it the most ideal and cost-efficient storage solution for environments like virtualization that contain dynamically-changing workloads. -
Extend NAS functionality with PCIe slots
The TS-1677XU-RP features four PCIe slots that allow for installing 10GbE/40GbE network cards, QM2 M.2 SSD/10GbE PCIe cards, or compatible wireless network cards for greater application potential. -
Fuel GPU-accelerated computing with a 500W power supply
Graphics cards are optimized for graphical calculations and transformations, but require significantly more power compared to other hardware. The TS-1677XU-RP offers PCIe slots to support an AMD Radeon or NVIDIA graphics card and features a 500 watt power supply that provides a 8-pin (6+2) power connector and a 6-pin power connector to power a graphics card for boosting imaging processing in QTS and performance of virtual machines via GPU pass-through. -
Run multiple graphics cards in your TS-1677XU-RP to unleash greater potential
Featuring four PCIe slots, the TS-1677XU-RP allows you to insert up to two high-end graphics cards that work cooperatively to deliver incredible computing performance over a single graphics card. It helps lead to greater potential for accelerating NAS video processing and GPU computing, empowering data-intensive AI machine learning, and realizing GPU-pass-through to VMs. -
GPU-accelerated NAS for AI machine learning
The TS-1677XU-RP provides cutting-edge capabilities to help organizations develop cost-efficient AI-oriented Big Data storage solutions. Combined with a high-end graphics card and QNAP's "QuAI" AI developer package, the AMD Ryzen-based TS-1677XU-RP can be leveraged to quickly build, train, and optimize AI model-based services, beneficial for exploring intelligent services and greater business value. -
SSD caching and auto tiering enable 24/7 optimized storage efficiency
The TS-1677XU-RP provides four PCIe slots that allow for installing QNAP's innovative QM2 cards to add M.2 SSD applications, such as SSD caching, to the NAS. Using an SSD cache boosts overall system performance, and is perfect for improving the overall workflow of random IOPS demanding applications such as virtualization. Qtier Technology empowers the TS-1677XU-RP with auto tiering that further helps continuously optimize storage efficiency across M.2 SSD, SSD, high-capacity SATA drives, and the optional PCIe NVMe SSD with around-the-clock acceleration. The new Qtier 2.0 features IO-awareness that empowers SSD tiered storage with a cache-like reserved space to handle burst I/O in real time, greatly maximizing the advantages of SSD.
- QNAP TS-1677XU-RP - NAS server - 0 GB
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10Gbps SFP+
- Enclosure Type
- Rack-mountable - 3U
- Total Storage Capacity
- 0 GB
- Installed Devices / Modules Qty
- 0 (installed) / 16 (max)
- 48.1 cm x 57.35 cm x 13 cm
- 15.23 kg
- Processor
- 1 x AMD Ryzen 5 1200 3.4 GHz (6-core)
- Storage Controller
- RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 50, JBOD, 60
- Networking
- GigE, 10 GigE optical
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Storage Operating System
- QNAP QTS 4.3.4
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
- NAS server
- Host Connectivity
- Enclosure Type
- 0 GB
- 48.1 cm
- 57.35 cm
- 13 cm
- 15.23 kg
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- 6-core
- Max Supported Qty
- 1
- Max Turbo Speed
- 3.9 GHz
- RAM
- 8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60
- Data Link Protocol
- TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, file sharing, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, bandwidth control, IPv4 support, surveillance station, online RAID capacity expansion, online RAID level migration, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, VPN client, Chromecast support, file station, IFTTT agent, FXP support, hybrid backup sync, Qfiling, Qsirch, Qcontactz, Qfinder Pro, Q'center (NAS CMS)
- Encryption Algorithm
- AES, FIPS 140-2, 256-bit AES
- UPnP
- Expansion Bays
- 16 (total) / 16 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 4 (total) / 2 (free) x DIMM 288-pin , 2 (total) / 2 (free) x PCI Express 3.0 x8 , 2 (total) / 2 (free) x PCI Express 3.0 x4
- 2 x Ethernet 1000Base-T - RJ-45 , 1 x USB 3.1 - Type A , 4 x USB 3.0 - Type A , 1 x USB 3.1 Gen 2 - Type C , 2 x Ethernet 10Gb - SFP+
- Cables Included
- 2 x network cable
- Built-in 4 cooling fans
- Included Accessories
- 64 x flat head screws (for 3.5" HDD), 64 x flat head screws (for 2.5" HDD)
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 136.45 Watt
- Power Provided
- 500 Watt
- QNAP QTS 4.3.4
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Sound Emission
- 46.6 dBA
