QNAP TS-1677X-1700-64G 16 Bay Desktop NAS - Diskless
Quicklinx: DMM0WS00 Mfr#: TS-1677X-1700-64G
QNAP TS-1677X - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
0 (installed) / 16 (max)
36.989 cm x 31.98 cm x 30.384 cm
13.39 kg ()
1 x AMD Ryzen 7 1700 3 GHz (8-core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, JBOD, 60
100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
IP Cameras Supported
3000
RAM
64 GB
Storage Operating System
QNAP QTS 4.3.4
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X Lion 10.7, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
NAS server
Host Connectivity
Total Storage Capacity
0 GB
36.989 cm
31.98 cm
30.384 cm
13.39 kg ()
Built-in Devices
Speaker, status LCD
Processor / Memory
Processors Installed
Number of Cores
8-core
Max Turbo Speed
3.7 GHz
RAM
64 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, SMB, DDNS
Remote Management Protocol
SNMP 2, SNMP, Telnet, SNMP 3, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, DDNS, Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
NAT support, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, IPv6 support, firmware upgradable, proxy server, Spanning Tree Protocol (STP) support, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, Network Access Protection (NAP), bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, Dropbox support, Real-time Remote Replication (RTRR), Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, DLNA support, file station, hubiC support, OpenStack Swift-compatible, WebDAV server support, port trunking, Microsoft Azure support, Amazon S3 support, Amazon Glacier suport, HiDrive support, RTRR server, RTRR client
Encryption Algorithm
SSL
UPnP
Security DVR
3000
Expansion Bays
12 (total) / 12 (free) x hot-swap - 3.5" , 4 (total) / 4 (free) x hot-swap - 2.5"
Expansion Slots
4 (total) / 2 (free) x DIMM 288-pin , 1 x PCI Express 3.0 x8 , 1 x PCI Express 3.0 x4 , 1 x PCI Express 2.0 x4
2 x Ethernet 10Gb - RJ-45 , 4 x Ethernet 1000Base-T - RJ-45 , 7 x USB 3.0 - Type A , 1 x USB 3.0 - Type C , 2 x microphone - mini-jack , 1 x audio out - mini-jack
Security lock slot (cable lock sold separately), built-in 3 cooling fans
Security Slot Type
Kensington security slot
FIPS 140-2, AES-256, SSL
Internal power supply
Power Provided
550 Watt
QNAP QTS 4.3.4
5 - 95% (non-condensing)
