QNAP TS-1635-4G
QNAP TS-1635-4G
Quicklinx: CK1MWS00 Mfr#: TS-1635-4G
  • Windows 8 (32/64 bits)
Supporting up to twelve 3.5" HDDs and four 2.5" SSDs, the TS-1635 is a powerful, high-capacity, quad-core business NAS. It includes two 10GbE SFP+ ports to fully support 10Gb high-speed networks with maximized ROI.
The TS-1635 also supports QNAP's network-based VJBOD (Virtual JBOD), providing an economical method for using unused storage space to expand the capacity of other QNAP NAS units. Furthermore, the TS-1635 features Container Station, which allows you to rapidly develop and deploy Internet of Things (IoT) apps, bringing a valued-added IoT business solution. The TS-1635 is a cost-effective storage solution designed for growing businesses looking for backup, restoration, private cloud, storage for virtualization, and to future-proof their IT infrastructure for 10GbE networks.
QNAP TS-1635 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
0 (installed) / 16 (max)
36.989 cm x 31.98 cm x 30.384 cm
12.22 kg ()
1 x Annapurna Labs Alpine AL-514 1.7 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 10 hot spare
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
RAM
4 GB
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
NAS server
Host Connectivity
Total Storage Capacity
0 GB
36.989 cm
31.98 cm
30.384 cm
12.22 kg ()
Built-in Devices
Speaker, status LCD
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 16 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 10 hot spare
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, DNS, Bonjour, SMB, DDNS, SFTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DNS, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Hardware encryption, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, download client, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, reset button, IPv4 support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR), Google Drive support, VPN client
Encryption Algorithm
SSL, 256-bit AES
UPnP
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" , 4 (total) / 4 (free) - 2.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCI Express 2.0 x2
2 x Ethernet 10Gb - SFP+ , 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
2 x network cable
Security lock slot (cable lock sold separately), built-in 3 cooling fans, AirPlay, One-Touch-Backup (OTB)
Security Slot Type
Kensington security slot
Internal power supply
78.45 Watt
Power Provided
250 Watt
QNAP QTS 4.2
5 - 95% (non-condensing)
