QNAP TS-1263XU-RP-4G 12 Bay Rack Mountable
Quicklinx: DMMCWS00 Mfr#: TS-1263XU-RP-4G
£1,637.35 ex VAT
£1,964.82 inc VAT
The cost-efficient 10GbE-ready TS-1263XU-RP is powered by a high-performance AMD G-Series quad-core processor. Featuring native 10GbE connectivity that delivers high performance with persistent throughput, along with storage scalability, the TS-1263XU-RP is perfect for businesses that demand higher bandwidth for data centers and virtualization.
QNAP TS-1263XU-RP - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
0 (installed) / 12 (max)
48.2 cm x 53.4 cm x 8.9 cm
13.1 kg
1 x AMD G-Series GX-420MC 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
100Mb LAN, GigE, 10 GigE, 5 GigE, 2.5 GigE
RAM
4 GB
Power Redundancy
Storage Operating System
QNAP QTS 4.3.4
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
0 GB
48.2 cm
53.4 cm
8.9 cm
13.1 kg
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 16 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, file sharing, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, bandwidth control, IPv4 support, surveillance station, online RAID capacity expansion, online RAID level migration, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, VPN client, Chromecast support, file station, IFTTT agent, FXP support, hybrid backup sync, Qfiling, Qsirch, Qcontactz, Qfinder Pro, Q'center (NAS CMS)
Encryption Algorithm
SSL, TLS, FIPS 140-2, 256-bit AES, AES-NI
UPnP
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCI Express 2.0 x4
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 1 x Ethernet 10Gb - RJ-45
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, built-in 2 cooling fans, scheduled power on/off
ISO 7779
12 x flat head screws (for 2.5" HDD), 16 x flat head screws (for 3.5" HDD), 2 x hangers, 2 x holders
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
143.17 Watt
Power Consumption Stand by
57.15 Watt
Power Provided
300 Watt
QNAP QTS 4.3.4
Shipping Weight
15.22 kg
5 - 95%
Sound Emission
39.2 dBA
Capacity: 0GB
Interface: 10 Gigabit Ethernet
Interface: 2.5 Gigabit Ethernet
Interface: 5 Gigabit Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Type: 12-Bay
Brand: QNAP
Price Range Ex VAT: 1500+
