QNAP TS-1231XU-RP-4G 12 bay NAS Rack Mountable
Quicklinx: D8B1WS00 Mfr#: TS-1231XU-RP-4G
The powerful quad-core TS-1231XU-RP includes two 10GbE SFP+ ports to fully support 10GbE high-speed networks at a budget price with maximized ROI. The TS-1231XU-RP provides versatile all-in-one functionalities and unique features including VJBOD (Virtual JBOD) - an economical way to utilize unused NAS storage space for expanding the storage capacity of other QNAP NAS - and Container Station - that allows users to rapidly develop and deploy Internet of Things (IoT) apps. The TS-1231XU-RP is a cost-effective storage solution designed for growing businesses looking for backup, restoration, private cloud, storage for virtualization, and to future-proof their IT infrastructure for 10GbE networks.
  • QM2 expansion card lets you redefine NAS server functions
    The QNAP QM2 is a PCIe expansion card equipped with two M.2 SSD slots and a 10G connectivity port. It allows users to easily configure the SSD cache to optimize NAS server performance. Models with 10GbE support also allow the TS-1231XU-RP server to prepare for future 10GbE networks. With its own cooling, the QM2 card can maintain high performance even under the most demanding workloads.
  • Accelerate performance with SSD cache
    The TS-1231XU-RP works with an SSD cache to significantly increase the input/output operations per second (IOPS) of storage volumes, thereby speeding up server performance. It superbly improves the overall performance of applications that require a lot of I/O operations per second, and features the best price/performance ratio thanks to the combination of SSD and HDD.
  • High reliability for business continuity
    The TS-1231XU-RP business model is designed to operate and provide services around the clock. Support for complex RAID configurations and hot-swappable drives ensures service continuity. QNAP's advanced RAID restore technology helps if you accidentally remove properly functioning drives from a degraded RAID volume. The system can be recovered by inserting the improperly removed hard drives and restoring data access. The TS-1231XU-RP provides high reliability and performance with support for multiple port trunking modes, including failover. The TS-1231XU-RP also features a hot-swappable, redundant power supply to ensure the longest possible system uptime without downtime.
  • QTS 4.3 - an intuitive and intelligent NAS server operating system
    QTS 4.3 provides smarter features, making management more efficient, including, among others, the Qfiling app, which helps categorize files and works with schedules to automate and streamline file organization. With an intuitive and simplified user interface, QTS has gained a smart desktop that allows you to quickly find desired functions, create or group shortcuts, monitor important system information in real time, and open multiple application windows to perform different tasks simultaneously. This increases the efficiency of the server. QTS breaks down device and platform barriers and geographic limitations, offering users optimized cloud functions, and includes advanced features.
  • Easily expand storage capacity
    The TS-1231XU-RP supports online capacity expansion by connecting QNAP expansion modules to store rapidly increasing amounts of data, which is especially useful for storage-intensive applications such as video surveillance, data archiving, TV broadcast recording and so on. The TS-1231XU-RP's storage can be expanded incrementally, on-demand, and you can use the Memory Manager app in QTS to easily manage the expansion of NAS storage and expansion modules.
QNAP TS-1231XU-RP - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
2U
0 (installed) / 12 (max)
48.2 cm x 53.4 cm x 8.9 cm
12.99 kg ()
1 x Annapurna Labs Alpine AL-314 1.7 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
IP Cameras Supported
72
RAM
4 GB
Storage Operating System
QNAP QTS 4.3
UNIX, Linux, Apple MacOS X, Microsoft Windows 7, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2
NAS server
Host Connectivity
Enclosure Type
2U
Total Storage Capacity
0 GB
48.2 cm
53.4 cm
8.9 cm
12.99 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 16 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Hardware encryption, VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, reset button, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR), Google Drive support
Encryption Algorithm
SSL, TLS, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
72
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCI Express 2.0 x2
2 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x Ethernet 10Gb - SFP+ , 1 x management
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, built-in 2 cooling fans, scheduled power on/off
Internal power supply
Installed Qty
2
Max Supported Qty
2
88.27 Watt
Power Provided
250 Watt
QNAP QTS 4.3
5 - 95% (non-condensing)
Sound Emission
47.6 dBA
