Your basket is empty
QNAP TS-112P/8TB-RED 1 Bay NAS
Quicklinx: C8G1WS00 Mfr#: TS-112P/8TB-RED
  • Windows 8 (32/64 bits)
The TS-112P is a powerful yet easy to use networked storage center for backup, synchronization, remote access, and home entertainment. As your personal cloud, you will always be connected to your files and your files are always under your control. See how TS-112P featuring the QTS 4.0 can make your digital life easier, simpler and more convenient.
QNAP TS-112P - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
8 TB
6 cm x 21.84 cm x 16.55 cm
1 x Marvell 88F6282 1.6 GHz
Storage Controller
SATA SATA 3Gb/s
Hard Drive
1 x 8 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
2700
RAM
512 MB
AC 120/230 V
Storage Operating System
QNAP Turbo NAS System 4.0
UNIX, Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
8 TB
6 cm
21.84 cm
16.55 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
RAM
512 MB DDR3
Flash Memory Installed
16 MB
Storage Controller
SATA
Interface Type
SATA 3Gb/s
Hard Drive
HDD - 3.5"
1 x 8 TB
Network / Transport Protocol
TCP/IP, iSCSI, SMTP, FTP, DHCP, PAP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, SNMP, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, IP address filtering, firmware upgradable, proxy server, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, RADIUS support, SSH support, iTunes server, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, DLNA Media Server, Apple Time Machine compatible, e-mail notification, cloud backup, VPN Server, SFTP client
DLNA CERTIFIED, UPnP
Security DVR
2700
Expansion Bays
1 (total) / 0 (free) x internal - 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x eSATA
1 x network cable , 1 x Serial ATA cable , 1 x Serial ATA power adapter
Audible alarm, K-lock security slot, built-in cooling fan
External power adapter
AC 120/230 V
Power Provided
36 Watt
Software Included
Drivers & Utilities
5 - 95% (non-condensing)
