QNAP TBS-453A-8G 4 Bay Desktop NAS
Quicklinx: C5WDWS00 Mfr#: TBS-453A-8G
  • Celeron
Compact, near-silent, and versatile, the 4-bay M.2 SSD NASbook TBS-453A is ideal for office meetings and multimedia applications. Featuring a powerful processor, a built-in 4-port network switch, and using up to 4 M.2 SSDs for storage, the TBS-453A not only provides full-fledged NAS functions with RAID protection, but also can act as a switch and share network access with multiple users regardless of being powered on or off. Coupled with its dual HDMI output and 4K H.264 video display & transcoding abilities, the TBS-453A can easily be carried to meetings to present stored files and quality multimedia content.
  • Handy, quiet and compact with four M.2 SSDs
    Designed with a "NASbook" concept, the TBS-453A uses a thin, B5-sized case to make it easy to setup anywhere in the office. The TBS-453A's usage of M.2 SSDs allows it to be significantly smaller and quieter. The RAM and M.2 SSDs are also easily accessible for installation and upgrading by removing the rubber pads and thumb screws on the bottom of the TBS-453A.
  • Optimal performance with CPU, AES-NI hardware-accelerated encryption, and M.2 SSDs
    The TBS-453A is powered by a powerful processor that can automatically burst up to 2.08GHz when performing CPU-intensive tasks. The built-in 2 Gigabit LAN ports can deliver up to 112MB/s throughput independently for optimizing mission-critical tasks. The TBS-453A features AES-NI hardware-accelerated encryption. With AES 256-bit encryption for full NAS volumes, the built-in 2 Gigabit LAN ports can deliver up to 109MB/s throughput independently.
  • Built-in four-port LAN switch for maximized network flexibility
    The TBS-453A includes additional hardware-based LAN switch ports with network switch mode and private network mode settings, allowing you to easily build a flexible network environment. In the default switch mode, users can simply use the TBS-453A's network switch functionality to share the Internet and NAS resources at the same time. While in the private network configuration, users can create a closed network, allowing them to create secure environments for activities such as creating a secure surveillance recording with IP cameras. The TBS-453A's network design greatly boosts collaboration and productivity at work as it ensures always-on Internet connectivity. Business meeting attendees, for example, could benefit from the network accessibility to access files stored on the TBS-453A or to search for information online during the meeting.
  • Dual HDMI output - switch between "duplicated" or "extended" desktop configurations
    The TBS-453A supports QNAP's exclusive QvPC technology and comes with dual HDMI output, enabling you to use the NAS as a PC with a keyboard, mouse and HDMI monitors. You can configure the displayed content on the two monitors in either a "duplicated" or "extended" desktop configuration. Duplicating will display the same content on both displays, and extended allows users to display applications over two displays for improved multitasking convenience and productivity.
  • Storage for hosting virtual machines and containerized applications
    Virtualization Station allows you to host virtual machines (VM) on the TBS-453A and access them via a web browser or VNC. Virtualization Station supports multiple operating systems, fast VM creation, VM backup & restoration, VM import/export, snapshot, and device management for centrally managing VM. Virtualization Station allows the TBS-453A and VMs to share the same LAN port. No longer constrained by physical network performance, high-speed Virtual Switches greatly increases data transfer between VMs as well as between VMs and NAS through the internal interface. The TBS-453A also features the game-changing container technology for server virtualization with QNAP Container Station. It exclusively integrates LXC and Docker lightweight virtualization technologies, allowing you to operate multiple isolated Linux systems on the TBS-453A as well as download apps from the built-in Docker Hub Registry.
  • Comprehensive data recovery with Snapshot, RTRR, and more
    The TBS-453A offers various data recovery options. The web-based snapshot tool helps easily backup and restore data on the TBS-453A back to any point of time. You can take up to 1024 snapshots for both volumes and LUN, efficiently replicate volume/LUN snapshots via Snapshot Replica to remote servers by copying only the changes made, and quickly clone a volume /LUN snapshot as a local volume without interrupting the current system operation. Windows users can also directly restore files from snapshots with the Previous Versions feature, saving time and effort without requiring IT support. RTRR (Real-Time Remote Replication) supports real-time or scheduled data backup to a remote QNAP NAS or FTP server and synchronizes files between remote and local folders. You can enjoy backup versioning to preserve a certain amount of versions, with options of simple versioning to schedule how many versions should be retained and for how long, or smart versioning with a rotation scheme that automatically replaces earlier backup versions. The TBS-453A also supports the rsync protocol to back up data to another remote server on a scheduled basis.
  • Cross-platform file sharing, centralized data storage
    The TBS-453A supports SMB/CIFS, NFS, and AFP protocols for file sharing across Windows, Mac, Linux /UNIX networks. Data, logs and ISO images of CDs and DVDs can be centrally stored on the TBS-453A and protected by an integrated antivirus solution. The Windows AD and LDAP services enable system administrators to configure user permissions by using an existing Windows AD server, LDAP server or built-in LDAP service. The TBS-453A supports SAMBA v4 and can act as a Windows domain controller to manage privilege settings.
  • Enhance productivity with multiple USB 3.0 ports
    Direct-attached Storage (DAS) devices such as USB hard drives are incredibly convenient in portability, but they fall short in file sharing and functionality and can only be connected to one server or PC at one time. By connecting a DAS to the TBS-453A you can easily share its content with other users without having to unplug and move it around. The USB ports on the TBS-453A also support devices such as UPS and printers for greater all-round functionality.
  • LED indicators with adjustable brightness controls
    With adjustable 20-stage brightness controls for LED indicators, the TBS-453A provides flexible LED brightness options. Based on the surrounding environment, you can adjust the brightness of all system indicators and also schedule the system to automatically dim the LEDs at certain times when needed.
QNAP TBS-453A M.2 SSD NASbook - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 4 (max)
23 cm x 16.5 cm x 2.5 cm
724 g ()
1 x Intel Celeron N3150 1.6 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
4
RAM
8 GB
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
23 cm
16.5 cm
2.5 cm
724 g ()
Built-in Devices
Speaker, led panel, 4 port switch
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
4 GB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Card Reader
Supported Flash Memory Cards
SD Memory Card
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Switching, VPN support, LDAP support, wake on LAN (WOL), Syslog support, dynamic DNS server, manageable, E-mail alert, print server, IPv6 support, proxy server, backup server, download client, file sharing, event log, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, Samba support, FTP server, SMS alert, UPnP Media Server, Domain Controller, reset button, Digital Volume Control, bandwidth control, IPv4 support, surveillance station, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, Apple AirPlay, signage station
Encryption Algorithm
SSL, 128-bit AES, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
4
Expansion Bays
4 (total) / 4 (free) x internal
Expansion Slots
2 (total) / 0 (free) x SO-DIMM 204-pin
5 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x HDMI output , 1 x USB 2.0 - Type A , 2 x microphone - mini-jack , 1 x audio out - mini-jack
2 x network cable
Security lock slot (cable lock sold separately), SNMP support
FIPS 140-2
External power adapter
15.2 Watt
Power Provided
65 Watt
QNAP QTS 4.2
Software Included
Qsync
5 - 95% (non-condensing)
Sound Emission
10.8 dBA
