Product
Brand
QNAP REXP-1620U-RP/32TB-RED PRO Rackmount NAS
Quicklinx: C2PVWS00 Mfr#: REXP-1620U-RP/32TB-RED PRO
The QNAP REXP-1600U-RP expansion enclosure is designed for expanding the storage space on the Turbo NAS and can support maximum 1 PB raw capacity by connecting multiple expansion enclosures via high speed mini SAS cables. This is especially useful for large data applications, such as video surveillance, data archiving, and TV broadcast storage.
QNAP REXP-1620U-RP - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 3U
Total Array Capacity
32 TB
SAS 12Gb/s
16 (installed) / 16 (max)
Supported Drives
SATA-600 / SAS-3
Storage Controller
(SATA 6Gb/s / SAS 12Gb/s)
Hard Drive
16 x 2 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
44.24 cm x 52.83 cm x 13 cm
Storage enclosure
Enclosure Type
Rack-mountable - 3U
Chassis
16
Supported Devices / Modules Qty
16
Supported Drives
SATA-600 / SAS-3
Storage
32 TB
HDD Array External Interface
SAS 12Gb/s
Storage Controller
Interface Type
Hard Drive
HDD - hot-swap
16 x 2 TB
Expansion Bays
16 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
3 x SAS 12Gb/s
Lockable, built-in 3 cooling fans, hot-swappable fans
1 x SAS cable - 50 cm
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
204.4 Watt
Power Provided
650 Watt
44.24 cm
52.83 cm
13 cm
5 - 95% (non-condensing)
