The QNAP REXP-1600U-RP expansion enclosure is designed for expanding the storage space on the Turbo NAS and can support maximum 1 PB raw capacity by connecting multiple expansion enclosures via high speed mini SAS cables. This is especially useful for large data applications, such as video surveillance, data archiving, and TV broadcast storage.
- QNAP REXP-1620U-RP - storage enclosure
- Storage enclosure
- Enclosure Type
- Rack-mountable - 3U
- Total Array Capacity
- 64 TB
- Interface
- SAS 12Gb/s
- Installed Devices / Modules Qty
- 16 (installed) / 16 (max)
- Supported Drives
- SATA-600 / SAS-3
- Storage Controller
- (SATA 6Gb/s / SAS 12Gb/s)
- Hard Drive
- 16 x 4 TB HDD - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 44.24 cm x 52.83 cm x 13 cm
- Storage enclosure
- Enclosure Type
Chassis
- 16
- Supported Devices / Modules Qty
- 16
- Supported Drives
- SATA-600 / SAS-3
Storage
- 64 TB
- HDD Array External Interface
- SAS 12Gb/s
- CPU
- No CPU
Storage Controller
- Interface Type
- SATA 6Gb/s / SAS 12Gb/s
Hard Drive
- HDD - hot-swap
- Capacity
- 16 x 4 TB
- Expansion Bays
- 16 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
- 3 x SAS 12Gb/s - 36 pin 4x Mini SAS HD (SFF-8644) , 1 x serial - 9 pin D-Sub (DB-9)
- Lockable, built-in 3 cooling fans
- Cables Included
- 1 x SAS cable - 50 cm
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 204.4 Watt
- Power Provided
- 650 Watt
- 44.24 cm
- 52.83 cm
- 13 cm
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
