QNAP REXP-1610U-RP 16 Bay SATA Expansion Unit
Quicklinx: DK3XWS00 Mfr#: REXP-1610U-RP
The REXP-1610U-RP expansion enclosure is designed for expanding the storage space on NAS by attaching multiple expansion enclosures via high-speed mini SAS cables. It is a flexible and budget-friendly solution for organizations to tackle applications with intense data growth without needing a large up-front investment.
  • Plug and use, seamless capacity expansion
    Simply connect a REXP-1610U-RP to a compatible NAS and power it on.
  • Missing mode protection
    If the disconnection of an expansion enclosure is detected, the NAS blocks I/O access to protect data. The system can recover from missing mode to its normal state with the data staying intact.
QNAP REXP-1610U-RP - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 3U
0 (installed) / 16 (max)
Supported Drives
SATA-600
Hard Drive
No HDD
AC 120/230 V - 50/60 Hz
Power Redundancy
44.24 cm x 52.83 cm x 13 cm
18.14 kg
Storage enclosure
Enclosure Type
Rack-mountable - 3U
Chassis
0
Supported Devices / Modules Qty
16
Supported Drives
SATA-600
CPU
No CPU
Hard Drive
No HDD
Expansion Bays
16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
3 x SAS 6Gb/s - 36 pin 4x Mini SAS HD (SFF-8644)
Built-in 3 cooling fans, hot-swappable fans
1 x SAS cable - 50 cm
Screws
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
204.4 Watt
Power Provided
650 Watt
44.24 cm
52.83 cm
13 cm
18.14 kg
5 - 95% (non-condensing)
Sound Emission
36.7 dBA
