Product
Brand
QNAP REXP-1220U-RP/48TB-RED PRO 12 Bay Rackmount NAS
Quicklinx: C2WKWS00 Mfr#: REXP-1220U-RP/48TB-RED PRO
The REXP-1220U-RP expansion enclosure is designed for expanding the storage space on a QNAP NAS by connecting multiple expansion enclosures via high-speed mini SAS cables. Featuring a 12 Gbps SAS interface on the chassis, the REXP-1220U-RP ensures fast data passthrough from 12 Gbps SAS-enabled QNAP NAS even when using 6Gbps hard drives. This is especially useful for large data applications that require high performance interconnection, such as video surveillance, archiving large data, and TV broadcast storage.
QNAP REXP-1220U-RP - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
48 TB
SAS 12Gb/s
12 (installed) / 12 (max)
Supported Drives
SATA-600 / SAS-3
Built-in Devices
Led panel
Storage Controller
(SATA 6Gb/s / SAS 12Gb/s)
Hard Drive
12 x 4 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
43.9 cm x 52 cm x 8.8 cm
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
Built-in Devices
Led panel
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS-3
Storage
48 TB
HDD Array External Interface
SAS 12Gb/s
Storage Controller
Interface Type
Data Transfer Rate
1.2 GBps
Max Storage Devices Qty
12
Hard Drive
HDD - hot-swap
12 x 4 TB
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
3 x SAS 12Gb/s - 36 pin 4x Mini SAS HD (SFF-8644)
Lockable, built-in 3 cooling fans, hot-swappable fans
1 x SAS cable - 50 cm
EIA-310-D
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
162.47 Watt
Power Provided
400 Watt
43.9 cm
52 cm
8.8 cm
5 - 95% (non-condensing)
Sound Emission
46.1 dBA
