The REXP-1210U-RP expansion enclosure is designed for expanding the storage space on a QNAP NAS by attaching multiple expansion enclosures via high-speed mini SAS cables. It is a flexible and budget-friendly solution for organizations to tackle applications with intense data growth without needing a large up-front investment.
Plug and use, seamless capacity expansion
Simply connect a REXP-1210U-RP to a compatible NAS and power it on. The NAS will detect the hard drives in the REXP-1210U-RP as local drives. -
Missing mode protection
If the disconnection of an expansion enclosure is detected, the NAS blocks I/O access to protect data. The system can recover from missing mode to its normal state with the data staying intact.
- QNAP REXP-1210U-RP - storage enclosure
- Storage enclosure
- Enclosure Type
- Rack-mountable - 2U
- Interface
- SAS 6Gb/s
- Installed Devices / Modules Qty
- 0 (installed) / 12 (max)
- Supported Drives
- SATA-600
- Storage Controller
- (SATA 6Gb/s)
- Hard Drive
- No HDD
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 43.9 cm x 52 cm x 8.8 cm
- 14.8 kg
- Storage enclosure
- Enclosure Type
Chassis
- 0
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SATA-600
Storage
- HDD Array External Interface
- SAS 6Gb/s
- CPU
- No CPU
Storage Controller
- Interface Type
- SATA 6Gb/s
- Max Storage Devices Qty
- 12
Hard Drive
- No HDD
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
- 3 x SAS 6Gb/s - 36 pin 4x Mini SAS HD (SFF-8644)
- Built-in 3 cooling fans, hot-swappable fans
- Cables Included
- 1 x SAS cable - 50 cm
- Included Accessories
- Screws
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 162.47 Watt
- Power Provided
- 400 Watt
- 43.9 cm
- 52 cm
- 8.8 cm
- 14.8 kg
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Sound Emission
- 46.1 dBA
