Product
QNAP REXP-1210U-RP 12 Bay SATA Expansion Unit
Quicklinx: DK42WS00 Mfr#: REXP-1210U-RP
Type: Storage enclosure
Controller Type: Serial ATA
Hurry, only 1 left in stock!
£1,321.86 ex VAT
£1,586.23 inc VAT
The REXP-1210U-RP expansion enclosure is designed for expanding the storage space on a QNAP NAS by attaching multiple expansion enclosures via high-speed mini SAS cables. It is a flexible and budget-friendly solution for organizations to tackle applications with intense data growth without needing a large up-front investment.
  • Plug and use, seamless capacity expansion
    Simply connect a REXP-1210U-RP to a compatible NAS and power it on. The NAS will detect the hard drives in the REXP-1210U-RP as local drives.
  • Missing mode protection
    If the disconnection of an expansion enclosure is detected, the NAS blocks I/O access to protect data. The system can recover from missing mode to its normal state with the data staying intact.
QNAP REXP-1210U-RP - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
SAS 6Gb/s
0 (installed) / 12 (max)
Supported Drives
SATA-600
Storage Controller
(SATA 6Gb/s)
Hard Drive
No HDD
AC 120/230 V - 50/60 Hz
Power Redundancy
43.9 cm x 52 cm x 8.8 cm
14.8 kg
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SATA-600
Storage
HDD Array External Interface
SAS 6Gb/s
Storage Controller
Interface Type
SATA 6Gb/s
Max Storage Devices Qty
12
Hard Drive
No HDD
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
3 x SAS 6Gb/s - 36 pin 4x Mini SAS HD (SFF-8644)
Built-in 3 cooling fans, hot-swappable fans
1 x SAS cable - 50 cm
Screws
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
162.47 Watt
Power Provided
400 Watt
43.9 cm
52 cm
8.8 cm
14.8 kg
5 - 95% (non-condensing)
Sound Emission
46.1 dBA
Brand: QNAP
Price Range Ex VAT: 1000 - 1500
