Product
QNAP RAIL-B01 2u Rack Rail Kit
Quicklinx: 9C7SWS00 Mfr#: RAIL-B01
Product Type: Rack rail kit
Stock Status: Clearance, Used Stock
Hurry, only 3 left in stock!
£62.30 ex VAT
£74.76 inc VAT
Rail kit for 2U rackmount models: TVS-x71U, TS-x53U, x70U, x69U
For use with:
  • TS-853U
  • TS-853U-RP
  • TS-1253U
  • TS-1253U-RP
  • TS-1269U-RP
  • TS-869U-RP
  • TVS-871U
  • TVS-1271U
  • TS-870U-RP
  • TS-1270U-RP
QNAP RAIL-B01 - rack rail kit - 2U
Rack rail kit
Package Content
2 rack rails
Height (Rack Units)
2U
78 cm x 5.5 cm x 9.7 cm
1.9 kg
Rack rail kit
Package Content
2 rack rails
Height (Rack Units)
2U
78 cm
5.5 cm
9.7 cm
1.9 kg
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 9C7S 035972
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £8.23
Ref: 9C7S 035973
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: QNAP
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
