QNAP QSW-804-4C 10GbE SFP+ Switch
Quicklinx: DQB4WS00 Mfr#: QSW-804-4C
Type: 10 Gigabit Ethernet
Ports: 8
Managed: No
£415.80 ex VAT
£498.96 inc VAT
The QNAP QSW-804-4C is an unmanaged switch, allowing you to instantly upgrade your network environment in a cost-effective way. With high performance, low latency and superb functionality, the QSW-804-4C is the ideal choice for upgrading your home or business connections.
QNAP QSW-804-4C - switch - 8 ports - unmanaged - rack-mountable
Switch - 8 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
4 x 10 Gigabit SFP+ + 4 x combo 10 Gigabit SFP+
Performance
Switching capacity: 160 Gbps
Priority queues: 8
MAC Address Table Size
27K entries
Jumbo Frame Support
9KB
Flow control, full duplex mode, Energy Efficient Ethernet, Class of Service (CoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az, IEEE 802.3bz
28.5 cm x 23.3 cm x 4.3 cm
2.1 kg
Enclosure Type
Desktop, rack-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
Priority queues: 8
27K entries
Jumbo Frame Support
9KB
Status Indicators
Port transmission speed, power, link/activity
4 x 10GBase-X SFP+ , 4 x 10GBase-T RJ-45
Internal power supply
41 Watt
Rack Mounting Kit
Included
28.5 cm
23.3 cm
4.3 cm
2.1 kg
10 - 85% (non-condensing)
Ports: 8
Managed: No
Brand: QNAP
