The IS-453S is a robust all-in-one industrial NAS designed for reliable operations in harsh environments. Featuring a fanless design with high vibration and impact resistance, the IS-453S is ideal for factories, warehouses, and transportation with operating temperatures between -40°C and 50°C (-40°F to 122°F). The IS-453S delivers high performance with persistent throughput and provides a comprehensive storage solution.
- QNAP IS-453S - NAS server - 32 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 32 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 18 cm x 24.7 cm x 5.9 cm
- Processor
- 1 x Intel Atom 1.91 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
- Hard Drive
- 4 x 8 TB
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 2 GB
- Power
- AC 120/230 V
- Storage Operating System
- QNAP QTS 4.2
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 32 TB
- 18 cm
- 24.7 cm
- 5.9 cm
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 8 GB (supported) - DDR3L
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 8 TB
- Data Link Protocol
- TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, DDNS
- Remote Management Protocol
- SNMP 2, SNMP, Telnet, SNMP 3, HTTP, HTTPS, SSH
- Network Services Compatibility
- DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- VPN support, trunking, print server, IPv6 support, DFS support, proxy server, iTunes server, Digital Optical Monitoring (DOM) support, Jumbo Frames support, DHCP server, Samba support, SMS alert, UPnP Media Server, DLNA Media Server, DHCP client, cloud backup, Wi-Fi USB dongle support
- Encryption Algorithm
- SSL, TLS, 256-bit AES
- UPnP
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5"
- Expansion Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 1 x HDMI output
- Cables Included
- 2 x network cable
- Fanless, rugged
- FCC Class B certified, FIPS 140-2, MIL-STD 810G 514.6
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 10.04 Watt
- Power Provided
- 90 Watt
- QNAP QTS 4.2
- OS Required
- -40 °C
- 50 °C
- 5 - 95% (non-condensing)
