The award winning Evoke range is a family of classic digital radios - brought right up to date. The perfect introduction, Evoke D1 is a stylish DAB digital and FM radio with compact footprint that will fit in perfectly anywhere, from the bedside table to the kitchen.
Perfect portable radio
Use mains power, or enjoy up to 30 hours of portable listening with an optional rechargeable ChargePAK B1. ChargePAKs are an economical and environmentally friendly fit-and-forget solution that charges in your radio while it is connected to the mains so you’re always ready to go.
Compact but feature-packed
With its small footprint, Evoke D1 makes an ideal bedside or kitchen radio. Features include 20 presets for quickly selecting your favourite stations, large easy-to-read clock, a sleep timer to automatically switch off your radio and a convenient countdown kitchen timer. There’s also a tone or radio alarm, stereo headphone socket and an aux-in socket which lets you plug in your mobile or tablet and hear your own music through your radio.
Switch on to digital radio
DAB digital radio brings you high-detail digital-quality sound, lots of stations (many exclusive to digital) and uses scrolling text to show you track titles, programme names and more. Digital radios automatically find all your available stations and let you select them by name, and all our digital radios also include FM for any stations that have not yet gone digital. Evoke D1 is also Digital Tick approved so you can rest assured that you’re ready for any future FM to digital radio switchover.
20 Presets
Set up to 20 preset stations, for quick access to your most listen to stations.
Tone or Radio Alarm
Go to sleep listening to your favourite station and let the radio take care of switching itself off, then waking you up again in the morning. Choose between a Tone Alarm and the Radio.
Different station presets
Quickly select DAB/FM stations of your choice. -
Alarms
Wake up to your favorite radio station or a tone alarm. -
Aux-in
Play your own music from any compatible device. -
Sleep timer
Put your radio into standby after a set time period. -
Kitchen timer
Set a countdown timer that ends with an alarm.
- PURE EVOKE D1 - DAB portable radio
- Product Type
- Enclosure Colour
- Black
- 11.5 cm x 12 cm x 18 cm
- Display
- LCD monochrome
- Radio
- DAB/DAB+/DMB/FM
- Speakers
- 1 x speaker - built-in - 1.6 Watt
- Power
- AC 230V
- 3-year warranty
- Product Type
- Enclosure Colour
- Black
Audio System
- Functions
- DAB radio, radio
Display
- LCD - monochrome
Speaker System
- Speakers
- Driver Details
- Speaker: 1 x full-range driver - 3"
Radio
- Radio Tuner
- Digital radio tuner - DAB/DAB+/DMB/FM
- Tuning Display
- LCD display
- Aerial Form Factor
- Telescopic
- Connector Type
- USB (mini-USB Type B) , Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
- ETSI, C-Tick, EMC 2004/108/EC, LVD 2006/95/EC
- Power Device
- Power adapter
- Voltage Required
- AC 230V
- Limited warranty - 3 years
- 11.5 cm
- 12 cm
- 18 cm
