Whether you require a replacement battery, or an additional pack to keep you working, PSA has a power solution to match.
- 2-Power Main Battery Pack - laptop battery - Li-Ion - 6600 mAh
- Laptop battery
- 420 g
- Battery
- Lithium Ion - 6600 mAh
- Battery Form Factor
- Internal
- Dark grey
- 7.6 cm x 16.3 cm x 2 cm
- Designed For
- Panasonic Toughbook CF-51
- Laptop battery
- Battery Enclosure Type
- Internal
- Dark grey
- Technology
- Lithium Ion
- Voltage Provided
- 11.1 V
- Capacity
- 6600 mAh
- 7.6 cm
- 16.3 cm
- 2 cm
- 420 g
- Designed For
