PSA Parts Main Battery Pack 7.6V 5900mAh
Quicklinx: D5TNWS00 Mfr#: CBP3529A
Sorry but this product has been discontinued.
View used stock
2-Power Main Battery Pack - Laptop battery - 1 x lithium polymer 4-cell 5900 mAh - for Lenovo Yoga 3 Pro
2-Power Main Battery Pack - laptop battery - Li-pol - 5900 mAh
Laptop battery
215 g
Lithium polymer 4-cell - 5900 mAh
Batteries Qty
1
29.4 cm x 16.2 cm x 0.2 cm
1 year warranty
Lenovo Yoga 3 Pro
Laptop battery
Quantity
1
4-cell lithium polymer
Voltage Provided
7.6 V
5900 mAh
Limited warranty - 1 year
29.4 cm
16.2 cm
0.2 cm
215 g
Lenovo Yoga 3 Pro
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: D5TN 037464
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £10.44
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
