Be productive longer than with standard battery solutions with the HP VI04XL Long Life Notebook Battery, which has up to a three-year lifespan to help lower your total cost of ownership. Help reduce your overall battery waste by using fewer batteries over the life of the notebook.
Award-winning support
Rest easy with a three-year parts replacement limited warranty. Additional support is available (North America only) seven days a week, 24 hours a day by phone, as well as through online support forums. -
Better run time
Use this long-life battery with select HP 400 Series Notebook PCs to keep working between charges, or carry one as a backup when you can't stop to plug in. -
Smart design
Get longer battery life in a thin design that integrates into the notebook's sleek profile.multilingual
- HP VI04XL - laptop battery - Li-Ion - 2800 mAh - 40 Wh
- Laptop battery
- 226 g
- Battery
- Long life - Lithium Ion 4-cell - 2800 mAh - 40 Wh
- 3.242 cm x 27.48 cm x 2.078 cm
- Designed For
- ProBook 440 G2 Notebook, 450 G2 Notebook, 455 G2 Notebook
- Laptop battery
- Long life
- Technology
- 4-cell Lithium Ion
- Voltage Provided
- 14.8 V
- Capacity
- 2800 mAh - 40 Wh
- Recharge Time
- 2.1 hours
- 3.242 cm
- 27.48 cm
- 2.078 cm
- 226 g
- Designed For
- HP ProBook 440 G2 Notebook, 450 G2 Notebook, 455 G2 Notebook
