PSA Parts Main Battery Pack 14.8V 2800mAh 40Wh
Quicklinx: CZ3XWS00 Mfr#: 756746-001
Be productive longer than with standard battery solutions with the HP VI04XL Long Life Notebook Battery, which has up to a three-year lifespan to help lower your total cost of ownership. Help reduce your overall battery waste by using fewer batteries over the life of the notebook.
  • Award-winning support
    Rest easy with a three-year parts replacement limited warranty. Additional support is available (North America only) seven days a week, 24 hours a day by phone, as well as through online support forums.
  • Better run time
    Use this long-life battery with select HP 400 Series Notebook PCs to keep working between charges, or carry one as a backup when you can't stop to plug in.
  • Smart design
    Get longer battery life in a thin design that integrates into the notebook's sleek profile.multilingual
HP VI04XL - laptop battery - Li-Ion - 2800 mAh - 40 Wh
Laptop battery
226 g
Long life - Lithium Ion 4-cell - 2800 mAh - 40 Wh
Batteries Qty
1
3.242 cm x 27.48 cm x 2.078 cm
ProBook 440 G2, 450 G2, 455 G2
Laptop battery
Long life
Quantity
1
4-cell Lithium Ion
Voltage Provided
14.8 V
2800 mAh - 40 Wh
Recharge Time
2.1 hours
3.242 cm
27.48 cm
2.078 cm
226 g
HP ProBook 440 G2, 450 G2, 455 G2
