This product is a high quality internal battery to replace your CBI2085A. You can get extra performance for using a spare CBI2085A.
- 2-Power - laptop battery - Li-Ion - 4600 mAh
- Laptop battery
- 308 g
- Battery
- Lithium Ion - 4600 mAh
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Black
- 20.5 cm x 4.2 cm x 2.1 cm
- 1-year warranty
- Designed For
- Dynabook Toshiba Satellite Pro U300; Toshiba Tecra M8; Toshiba Satellite U300
- Laptop battery
- Battery Enclosure Type
- Internal
- Black
- Quantity
- 1
- Technology
- Lithium Ion
- Voltage Provided
- 10.8 V
- Capacity
- 4600 mAh
- Limited warranty - 1 year
- 20.5 cm
- 4.2 cm
- 2.1 cm
- 308 g
- Designed For
- Dynabook Toshiba Satellite Pro U300, U300-002, U300-003, U300-100, U300-106, U300-10U, U300-10W, U300-10Z, U300-116, U300-11K, U300-11R, U300-121, U300-13F, U300-13O, U300-13P, U300-13R, U300-13Y, U300-142, U300-143, U300-148, U300-14D, U300-14R, U300-14S, U300-15B, U300-15C, U300-15D, U300-15N, U300-RW1, U300-RW7, U300-SP1809 , Dynabook Toshiba Tecra M8, M8-RW8, M8-S8011, M8-S8011X, M8-ST3093, M8-ST3094 , Toshiba Satellite U300, U300-102, U300-10M, U300-10S, U300-111, U300-112, U300-113, U300-114, U300-115, U300-11P, U300-11Q, U300-11V, U300-11Y, U300-11Z, U300-12D, U300-12G, U300-12S, U300-130, U300-134, U300-137, U300-13H, U300-13I, U300-13J, U300-13K, U300-13L, U300-13M, U300-13N, U300-13U, U300-13V, U300-13Z, U300-141, U300-144, U300-14B, U300-14K, U300-14O, U300-14P, U300-14Q, U300-14U, U300-14Z, U300-150, U300-151, U300-152, U300-153, U300-154, U300-159, U300-15A, U300-15C, U300-15P, U300-15Q, U300-15S, U300-15W, U300-AY1, U300-AY3, U300-NS1, U300-NS5, U300-ST3091, U300-ST3094, U300-TP2, U300-TP7
