Duracell Compact Battery Charger
The Duracell Compact Battery Charger can fully charge your camera battery in under 2 hours. The charger is supplied with a mains wall adapter for use around the home. This charger has an LED light which indicates the status of a charge at any time as well as in built safety features meaning it will never over charge your battery.
- Duracell battery charger
- Product Type
- Battery charger
- Localisation
- United Kingdom
- Voltage Required
- AC 230 V
- 3-year warranty
- Designed For
- Nikon EN EL1, EL10, EL11, EL12, EL2, EL5, EL8
- Product Type
- Battery charger
- Designed For
- Camcorder, camera
- Localisation
- United Kingdom
- Voltage Required
- AC 230 V
- LED indicator, short circuit protection
- Limited warranty - 3 years
- Designed For
