- PSA battery - Li-Ion
- Product Type
- Battery
- 4.3 cm x 3 cm x 4.1 cm
- 80 g
- Battery
- Lithium Ion - 3440 mAh
- 1-year warranty
- Designed For
- Panasonic HC-V10, V100, V500, V700, HDC-HS60, HS80, SD60, SD66, SD80, SD90, SD99, SDX1, SDX1EC-H, SDX1EG-H, SDX1EG-K, SDX1EG-V, SDX1H, TM35, TM41, TM55, TM60, TM80, TM90, TM99, SDR-H100, H101, H85, H86, S45, S50, S70, S71, T50, T55, T70
- Product Type
- Battery
- 4.3 cm
- 3 cm
- 4.1 cm
- 80 g
- Technology
- Lithium Ion
- Voltage Provided
- 3.6 V
- Capacity
- 3440 mAh
- Limited warranty - 1 year
- Designed For
- Panasonic HC-V100, HC-V100M, HC-V10M, HC-V500, HC-V500M, HC-V700, HC-V700M, HDC-HS60, HDC-HS60EB-K, HDC-HS60EF-K, HDC-HS60EG-K, HDC-HS60EP-K, HDC-HS60K, HDC-HS80, HDC-HS80EB-K, HDC-HS80EC-K, HDC-HS80EG-K, HDC-HS80EP-K, HDC-SD60, HDC-SD60EB-K, HDC-SD60EB-R, HDC-SD60EB-S, HDC-SD60EC-K, HDC-SD60EC-R, HDC-SD60EC-S, HDC-SD60ED-K, HDC-SD60EF-K, HDC-SD60EF-R, HDC-SD60EF-S, HDC-SD60EGK, HDC-SD60EG-K, HDC-SD60EG-R, HDC-SD60EGS, HDC-SD60EP-R, HDC-SD60K, HDC-SD60-R, HDC-SD60S, HDC-SD66, HDC-SD66EG-K, HDC-SD66EG-R, HDC-SD66EG-S, HDC-SD80, HDC-SD80EB-K, HDC-SD80EB-R, HDC-SD80EC-K, HDC-SD80EG-K, HDC-SD80EG-R, HDC-SD80EG-S, HDC-SD80EG-T, HDC-SD90, HDC-SD90EB-K, HDC-SD90EC-K, HDC-SD90EG-K, HDC-SD90EP-K, HDC-SD99, HDC-SD99EG-K, HDC-SD99EG-S, HDC-SDX1, HDC-SDX1EC-H, HDC-SDX1EG-H, HDC-SDX1EG-K, HDC-SDX1EG-V, HDC-SDX1H, HDC-TM35, HDC-TM41, HDC-TM55, HDC-TM55EB-K, HDC-TM55K, HDC-TM60, HDC-TM60EB-K, HDC-TM60EC-K, HDC-TM60EF-K, HDC-TM60EGK, HDC-TM60PU-K, HDC-TM80, HDC-TM80EF-K, HDC-TM80EG-K, HDC-TM80EP-K, HDC-TM90, HDC-TM99, SDR-H100, SDR-H100EG-K, SDR-H100EP-K, SDR-H101, SDR-H85, SDR-H85A, SDR-H85EB-K, SDR-H85EF-K, SDR-H85EF-R, SDR-H85EG-K, SDR-H85EG-R, SDR-H85EG-S, SDR-H85EP-K, SDR-H85K, SDR-H85S, SDR-H86, SDR-S45, SDR-S45EC-S, SDR-S45EF-S, SDR-S45EG-S, SDR-S45EP-S, SDR-S50, SDR-S50A, SDR-S50EB-A, SDR-S50EB-K, SDR-S50EB-R, SDR-S50EB-W, SDR-S50EC-K, SDR-S50EC-W, SDR-S50EF-A, SDR-S50EF-K, SDR-S50EF-R, SDR-S50EF-W, SDR-S50EG-A, SDR-S50EG-K, SDR-S50EG-N, SDR-S50EG-P, SDR-S50EG-R, SDR-S50EG-S, SDR-S50EG-W, SDR-S50EP-K, SDR-S50K, SDR-S50N, SDR-S50-R, SDR-S70, SDR-S70EB-K, SDR-S70EC-K, SDR-S70EG-K, SDR-S70EG-R, SDR-S71, SDR-T50, SDR-T50EB-K, SDR-T50EF-K, SDR-T50EG-K, SDR-T50EP-K, SDR-T50K, SDR-T55EB-K, SDR-T70, SDR-T70EG-K
