Perfect for enhancing sound when recording video on your DSLR or camcorder, the Proper shotgun microphone is a compact, lightweight solution whilst on the go. Easily mounted onto your cameras hot shoe, the super-cardioid polar pattern and integrated shock mount effectively suppresses any handling or vibration noise, enabling you to focus on the subject in front of the camera. This microphone ensures you will have enough time to capture as much footage as possible.
- Proper P-SM90PB-1 - microphone
- Product Type
- Microphone
- Recommended Use
- Camera, camcorder
- Microphone
- Shoe mount
- Microphone Technology
- Condenser
- Product Type
- Microphone
- 5.8 cm
- 22 cm
- 10.2 cm
- 121 g
- Recommended Use
- Camera, camcorder
Microphone
- Shoe mount
- Condenser
- Connectivity Technology
- Wired
- Microphone Power Source Voltage (DC)
- 9 V
- Frequency Response
- 40 - 20000 Hz
- Audio Input Details
- Super cardioid - 40 - 20000 Hz
- Connector Type
- Microphone (mini-phone 3.5mm)
- Cables Included
- Microphone cable
- Included Accessories
- Wind shield
- Battery
- 1 x battery - 9V
- Run Time (Up To)
- 100 hour(s)
